Can you flood an EFI?
Throttle position sensor....if it didn't come up chances are nothin's wrong with it but test it to be sure.....this writeup is for a single bore throttle body but it's exactly the same. http://www.f150online.com/forums/lig...ttle-body.html
on
Which test. key on engine off or key on engine running?
Remove, clean, reinstall & test !AC as per link instructions:
Ford Fuel Injection Idle Air Bypass (IAB)
on
Not the only potential culprit though. Hanging injectors, combustion chamber buildup to name a few.
Seafoam! How to Seafoam an Eighth Gen F150 (1987-1991) - Ford F150 Forum - Community of Ford Truck Fans
on
Wow, I guess so! How about over the internet from on of these companies?
http://www.seafoamsales.com/where-ca...-products.html
Check out the whole site when you go to this link!
Muddominator
11-10-2011 06:39 PM
