Ford 9 inch rearend
Ford 9 inch rearend
I am getting ready to swap in a 9in rearend. Will there be enough differences in size that I will need a shorter or longer drive shaft? I will be going from the stock 3.92 gears to 3.25 how will this effect perfomance and drivability with a 700-R4 transmission?
Forgot to ask also about lower shock brackets. I have brackets to go on the bottom side of the 3in axle. I am looking for shock brackets that bolt on the u-bolts like what was used on 57 ford trucks.
I don't know about the "newer" trucks but for the '48-52 trucks I was told the drive shaft comes up slightly short by about an inch. What about the width of the axle tubes? Are the newer trucks the same as the later ones? When swapping a 9" into a '48-52 truck you have to either build or buy spring brakets or use the spring brackets from a F-2 because the older 1/2 ton axles' tube diameter is smaller.
Rear Axle Page
I have a 9" for my stock '48 panel, just have to find the time to do the swap.
Rear Axle Page
Your 700R4 has gear ratios at 3.06/1.63/1.00/ and 0.70.
With a 3.25 rear end, that might be a little steep.
With 88" roll out tires (235/75R15s) you will be going 65 mph at 2500 rpm in third gear, and freeway speed (65) at 1850 rpm in overdrive.
Even if you go with a smaller back tire like a 245/60R15 you will be going 67 mph at 2000 rpm in overdrive.
An ideal rear end ratio with the larger tires (used to fill up the wheel wells) would be about 3.80.
Here's the rpm calculator for you to play with:
Gear Ratio Calculator
The only reference I have is for the '48-52, I don't know if there is much of a difference, but the best set up is use the mounting plates from a F-2, the F-2 axle is suppose to be about the same diameter as the 9". I also think some of the parts vendors like Mid 50s carries a kit. I'm sure some one will be along soon to offer better information.
I hope this helps and good luck with your build.
IMHO and experience 3.25 is to tall. I'm running 3.50 and it's still to tall so this winter I'm switching to a 3.73 gear set. I like this gear calculator; MOTOR - A Rear Axle Calculator
So I just did mine, Ford 9, purchased the rear-end upgrade kit from CPP and welded on the new shock mounts. I ended up having a new driveshaft built for a 100 bucks. the new rear-end sits under the springs. The kit comes with the new U -Bolts, axle plates and shockmount brackets. I did not use the new axle plates, the ones on the 9 fit perfectly. The new plates are for if you want to put the axle above the springs for lowering.
good luck.
good luck.
BarryB's
16
04-28-2010 11:28 PM
DGMFORD
03-27-2010 03:59 PM
Fedman
15
03-10-2010 08:16 PM
CharlieLed
09-22-2006 09:59 PM
