how to tell if EGR cooler is bad???
Old 08-24-2010, 02:26 PM
slamndually's Avatar
slamndually
slamndually is offline
i'm working on a 6.0 in an excursion and was wondering how do i tell if the EGR cooler is good or bad??? What are the signs of a bad one?? Thanks in advance.
Old 08-24-2010, 02:36 PM
UGA33's Avatar
UGA33
UGA33 is offline
White smoke while idling and possibly lots of white smoke. Coolant disappearing. Easiest way to tell is to pull the EGR valve and if there is a puddle in the intake or the valve is really wet, then the cooler is bad.
Old 08-24-2010, 02:48 PM
slamndually
thank you. EGR cooler is good than
Old 08-24-2010, 04:40 PM
bpounds's Avatar
bpounds
bpounds is offline
That's jumping to a conclusion pretty quick. What symptoms caused you to suspect the cooler? Are they still there? UGA33 describes the symptoms when things have gotten pretty bad. It can be leaking long before it reaches that point.
This TSB describes how to diagnose.
09-8-3*** COOLANT LOSS - 6.0L
Old 08-24-2010, 04:46 PM
slamndually
no was just asking if it was a visual thing or not. have turbo off and #7 injector out for replacement pulled EGR valve to inspect and clean and was looking at the cooler. no loss of coolant yet no smoke other than black created by bad injector. going through the normal stuff on this 6.0 to get it running good again. did the FICM repair yesterday that REALLY helped alot. Just trying to check everything while i got it apart. thanks Joe
Hellbringer
10-22-2014 12:01 PM
allingeneral
03-10-2014 06:01 PM
madhatt
02-25-2014 04:30 PM
i eat hybrids
12-20-2010 05:02 PM
FireBaller74
12-09-2010 10:43 AM
Quick Reply: how to tell if EGR cooler is bad???
