99 7.3 psd will not start without a shot of starter fluid
Old 10-12-2012, 07:18 PM
JohnDeereFarmerUSMC's Avatar
JohnDeereFarmerUSMC
JohnDeereFarmerUSMC is offline
hahaha, i do that all the frickin' time, usually catch myself right before i post though!
  #32
Old 10-12-2012, 07:54 PM
KelVarnson's Avatar
KelVarnson
KelVarnson is offline
So what's the harm of digging up an old thread? Better than starting a new one, IMO.
  #33
Old 10-12-2012, 08:01 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Originally Posted by johndeeregreen2013
im pretty certain the precombustion chamber were only existent in the 6.9 and 7.3 idi because of the indirect injection..natrally asspurated...am i right or wrong??
lol sry im not guna lie i never looked at the date just read the comment...was just searching around to enlighten myself on stuff i may not have seen before and got caught up with his comment
Thats all fine and dandy...
If you have SOMETHING to add... but when you add nothing but bring up a 5 month old thread...
Just sayin...
  #34
Old 10-12-2012, 08:10 PM
KelVarnson's Avatar
KelVarnson
...with ya on that...
  #35
Old 10-13-2012, 12:21 AM
1fixitman's Avatar
1fixitman
1fixitman is offline
I don't believe I read thru this whole thread and wasted my time. The OP's problem was never solved from what I read. Let me find something that I can learn more of.
  #36
Old 10-13-2012, 08:33 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
I'm with you Dwayne BUT...This is the classic case of someone who looks for help from members then for whatever reason, fails to complete the thread when/if he fixes the truck. To learn the most, there has to be a solution which solved the problem...without the OP giving that feedback to the board, the majority of the learning is lost.
Neal in fantasyland: I wish that when a person had a problem and started a thread, they had to put up a $5 deposit that was refundable when the problem was solved and he posted the solution.
  #37
Old 10-13-2012, 09:01 AM
srteach's Avatar
srteach
srteach is offline
Originally Posted by jwiseman
ok i have a 99 7.3l turbo diesel and i have recently been having alot of trouble getting it started. i know that starter fluid is bad for diesel so before everyone tells me..i already know..i have checked the hpop..not the problem, gpr, not the problem, glowplugs...not the problem. i know i have a slight fuel leak from the check valve that drains the water from the fuel..could it just be low fuel pressure? but when i shoot it with starting fluid or wd-40 it starts right up and runs perfect. o..and the check engine light randomly pops on only while im driving tho and especially when i punch the pedal...please helppp!!
I know this is an old post (please don't kill the messenger), but was there a resolution on the problem? Did the Op sell the truck or fix it?
WHAT HAPPENED????
  #38
Old 06-26-2014, 09:29 PM
Duckhunter1's Avatar
Duckhunter1
Duckhunter1 is offline
I am having the same issue
I am new and not sure how to get help here, but I have the same issue with my 99 7.3 I have 6 codes that come up
P1690
P0381
P1212
P1247
P0470
P1211
Any help?
  #39
Old 06-27-2014, 05:49 AM
Tugly's Avatar
Tugly
Tugly is offline
The last link in my signature... give it a click. Where are the scan tools you say? First link in my signature.
  #40
Old 03-13-2015, 05:08 PM
bobrogers's Avatar
bobrogers
bobrogers is offline
7.3 powerstroke no start without either
first time to post and i admit im lost..i have a 1996 f-350 with a 7.3l
im having the same issue with my truck it will not start without a shot
of brake clean.been doing this for about a week trying to get into a shop
i trust in my area to scan my codes.this started after a 40 mile run doing
75 mph...and by the way its got a e4od trans as well.always been kinda
rough to start when at operating temp but it would start.i use rotella 15w40
engine oil with a gallon of lucas because it makes me feel good not sure if
the truck likes it but it never says anything bad about it.i have replaced
one injector last may and it runs ok.seems to idle rough .i replaced the glow
plug relay today with high hopes . no better dont have any fuel leaks and
i dont see any oil in the intake valley.change my oil every 3k mabey over
kill but again makes me feel good.and the truck has 322k on it. help
oh and just in case it matters i added new motorcraft glow plugs and
harness at injector replacement.batterys are hot and she turns over
with out any issue.
  #41
Old 03-13-2015, 11:33 PM
HD Rider's Avatar
HD Rider
HD Rider is offline
Bob with 322k on the clock, your injectors are about done.
The hard starts when warm indicate HPO (high pressure oil) leak, likely injector o-rings. You can get a bluetooth OBDII adapter and the TorquePro app and scan your own codes for less than any shop will charge. Finding a shop that knows much about a 7.3 can be tough. Not even the dealers know them.
Welcome aboard.
thegreatgate
01-29-2017 10:39 AM
Probull
04-30-2016 08:34 PM
CoalRoller7.3
11-27-2012 12:34 PM
buschracer
07-19-2003 10:20 PM
Quick Reply: 99 7.3 psd will not start without a shot of starter fluid
