breather hoses / aftermarket breather
I'm thinking about putting an aftermarket breather on my 71 (302 cid). There's a hose that hooks in the same place the breather hose for the PCV system hooks in and goes down to a box (charcoal box?). Another line goes from that box toward the back of the truck... maybe to the gas tank? I know I'd have to get a breather for the valve cover for the PCV system, but what would I do with the other hose that connects to the breather if I went aftermarket?
Also, any opinions on switching to an open element breather?
Tom
Tom
if daily driver:
Put on a breather with a grommeted opening, use an PCV the fits the larger diameter grommet, use either 3/8 or 5/8 fuel grade hose and connect it straight to the manifold or to the botton of the carb.
if race:
open breather
If you run the open breathers, you will be amazed at how much crankcase oil fumes you will be breathing, especially at a stop. Was worth it for me not to have to breathe that cra......errr crud
if race:
open breather
Originally posted by Dave-ceedot
if daily driver:
if race:
open breather
if daily driver:
if race:
open breather
I think you're talking about the hose for the PCV system that goes from the breather to the valve cover? I was going to replace it with a valve cover breather.
I need to know what the other hose is and what to do with it. It goes from the breather to a box mounted on the frame rail. I think I've heard similar boxes called charcoal boxes. A line goes from that box toward the back of the truck... I think to the fuel tank.
Tom
Im not sure. You ahve a camper special or something that offered some sort of fuel-tank breather/filter? I've never seen one before. Sorry couldnt help you
Thanks for taking a stab at it... anyone else have suggestions? Anyone? Anyone? Bueller? Bueller? :)
You are talking about the hose from the charcole canister. It went to the stock air cleaner to pull the vapors from the canister. You could attach a fitting to the bottom of the air cleaner for it. I would make some kind of filter for it. That may not be necessary, don't know how much air would be pulled thru it.
Thanks for the help!
Tom
70-360fe
08-16-2012 07:38 AM
phurst
01-06-2011 06:07 PM
TexasGuy001
17
06-26-2009 11:25 AM
