PCV Valve vacuum leak!
Old Apr 19, 2014 | 05:48 PM
Buyerz's Avatar
Buyerz
After a while of looking to why my 78 400(new jasper) was idling rough, I found a small vacuum leak in the pcv system.
When I pull the hose off of the check valve on the oil fill cap and plug it it idles much nicer, but blows smoke out of the breather on the other valve cover. When I put it back on it goes back to idling rough with fluctuations in the vacuum, no steam. The check valve is still loose, and the breather isn't connected to anything since I have an aftermarket air cleaner. Most of the rest of the vacuum is removed and blocked. Any Ideas?
Thanks
Old Apr 19, 2014 | 06:24 PM
fmc400's Avatar
fmc400
MSEE
I'd try a dry compression test followed by a wet compression test. Sounds like worn rings if it won't run well with the PCV system closed. This assumes your breather can actually draw in fresh air (assuming so since it's disconnected).
Old Apr 19, 2014 | 06:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When I pull the hose off of the smog valve on the oil fill cap and plug it it idles much nicer, but blows smoke out of the breather on the other valve cover.
When I put it back on it goes back to idling rough with fluctuations in the vacuum, no steam. The smog valve is still loose, and the breather isn't connected to anything since I have an aftermarket air cleaner. Most of the rest of the vacuum is removed and blocked.
Smog valve fits into rubber grommet that fits into oil filler cap.
Old Apr 19, 2014 | 07:08 PM
Buyerz's Avatar
Buyerz
Its a brand new jasper engine with less than 2 hours on it.
Old Apr 19, 2014 | 08:06 PM
JWC 3's Avatar
JWC 3
I went through 3 ! before I got a good one back about 98 , from Them . I ran a compression test on the first one , ALL Over the place ! 2nd one would happily run , but mixed coolant and oil within 2 min. ! 3rd one was fine . I have not seen issues with their products recently , My shop installs many of their engines and trannys . We use their rear diffs some times also . Any one can make a mistake . Yours is in assuming there can be nothing wrong with a reman .
Old Apr 19, 2014 | 08:10 PM
Al T's Avatar
Al T
Thanks
Replace the PCV valve & change oil (brands).
Old Apr 19, 2014 | 11:22 PM
fmc400's Avatar
fmc400
MSEE
That doesn't change the diagnosis. It's doing what it's doing regardless of what it is. I can empathize with your frustration. A round of compression tests will eliminate all doubt. Hopefully I'm wrong.
annaleigh
Apr 19, 2016 02:28 AM
1985-f250
Jan 24, 2014 10:08 AM
mr_ranger-79
25
Feb 12, 2011 09:06 PM
Dr G
16
Jan 26, 2011 11:38 PM
Tom Cullen
15
Nov 28, 1999 08:28 PM
