'53 F100 query..
'53 F100 query..
My wife and I are making progress with our '53 F100...but now I am stuck, how do you get the clutch pedal off? I have found the nut on the pedal lever by the pivot point under the cab floor, and undone it, but how do I get the pedal off the shaft? Does the pivot shaft push all the way through to the brake pedal too?
I have attached a pic of the inboard end of the shaft, what does the bracket do?
Cheers,
Shane
Cheers,
Shane
Excellent, thanks
Thank you for that Julie, it is just what I needed!!
My wife has made a lot of progress, the truck is stripped back to the firewall, and the rear guards are off, and yesterday I cut the non-stock transmission support crossmember out that was added to support the olds trans that was installed sometime.
I can post pic's if anyone wants to see them....
I will also have to get a workshop manual....
Cheers,
Shane
Cheers,
Shane
Hi, there is a roll pin in the "J" shaped coller that is connected to the clutch "U" shaped metal throw, shown at the left of your picture. Use a suitable punch to knock it out and everything will slide off the shaft, clutch and brake pedals. You can then check the bushings they both move on. Cheers.
jerryst
17
05-07-2012 11:27 PM
cbutcher
15
12-10-2010 03:33 PM
Offroader6
13
12-18-2009 07:34 PM
alienbaby17
06-30-2006 11:52 PM
