The temp gauge is not working on my 1981 Ford Motor home. This unit has a Ford 460 CID engine. The sensor is located near the distributor.
My question is how can I test this sensor? And can I test the wiring back to the gauge by using a Ohm meter with the ignition turned on?
You proved that the problem is not the sender. Either the wire is broken, the gauge is bad or the power supply in the instrument cluster is bad. FYI the Power Supply is known for puking. Check to see if there is power at the sender on the wire.
It seems the better way to go. This motorhome is on a 1981 E350 frame. 29years and counting. I'm thinking I should replace the sensor too. Can you recommend a sensor or they "all the same"? Plus you might as well recommend a gauge if you feel like it.
