Superduty bed swap pictorial
#32
#33
I've gone through this twice on my bed. This last time, I broke several bits of varying professional qualities, including the "proper" bolt. Some of my problems included breaking the bit off flush with the bolt head. I couldn't get it out since I used the properly fitting bit. I was able to recover several of the bolts by a combination of working them back and forth with an impact and hitting them on the head with a hammer.
When i put the new ones in, which came as part of a kit, I used antiseize on the threads. I worked the new bolts back and forth several times putting them in to form the threads and insure that they would come out again, as my luck has it they will need to come out again.
They get stuck because of their design and that the nuts have no threads. The bolts become locked into the nuts. It's not from rust or corrosion that they won't free up in most cases. If I paused when initially putting them in they would be more difficult to remove. As long as I ran them back and forth I was able to work them in.
regular headed bolts or bolts with a larger torx bit would be easier to remove while still having them lock in and not back out.
#34
#35
Depending on the year truck you have, here's a description:
Welcome to guzzle's In-tank Harpoon Mod Web Page
#36
Thanks!
Mine is a 2001 with the 7.3, and judging from all the repairs it needs I am guessing it needs this mod too!
Working on finding a short box for it and will probably do this mod too.
Currently installing all 4 new loaded calipers & rotors, hanger bearing & new u-joints, axle joints & seals, steering stabilizer, shocks, and hopefully fixing a dipstick tube oil leak into the pan.
#39
#40
Get underneath and spray them down with penetrating oil a few days ahead of time. Gett a good Torx Plus bit the correct size (or a few, and impact rated). Hit them with an impact wrench both directions to work them loose. Applying anti-seize beforehand to the full length of threads helps too. I removed all bolts from my short bed and only had one that we stripped the torx head out on, on that one we ended up welding a nut to the top and then we got it out. I had a few extra bolts from the salvage yard so I didn't have to buy any new. I think I broke two bits, but they weren't impact rated.
#41
This truck was in a collision and the passenger bedside is mashed with some buckle on the bed that don't extend past the wheel hump. After hearing what a PITA these bolts are, I'm considering buying a used bed that has a good passenger side and having a body shop weld it onto the good driver's side and bed that I got. Found one at a random auction that oughta go cheap and the body shop quoted $800 to splice and paint it all to look right. Have you ever seen one done that way?
#42
#43
#44
