2005 Expedition transmission = dead?
#61
It should have a 4R75W transmission.
As far as the problem goes, the overdrive servo pistons has a small e clip the holds the servo together, this clip is known to break and fall down into the valvebody and jam the valve for 4th gear. If you can find a shop that is willing to remove the valvebody and check this out you might be able to fix it without rebuilding it.
Just so you know sometimes when the clip brakes it can cause the overdrive band to burn, once the pan is off you should be able to tell by the smell of the fluid and of any black debris in the bottom of the pan. You may end up having to rebuild it anyways, I would say that you have a 50-50 chance.
Any help would be great cause its my work truck and i don't want to damage it farther but can't afford to leave it home.
thanks
#62
The overdrive band has to apply during the 3-4 shift, if it doesn't apply it will feel like a neutral because the forward drum is released during that shift, so yes your description of your problem could be the stuck valve but you will need to remove the valve body to find out.
It is common to have the e clip and or the snap ring to break and pieces can get caught in the valve body and prevent the valve from moving, but I also see the band broken and or burnt as well.
Banks_93_IDI
15
02-27-2018 03:23 PM
Martok
01-03-2018 01:24 PM
Krameraxe
08-19-2016 08:02 PM
mytrustyford
20
08-15-2016 03:30 PM
