New bed
I agree you should frame it out using steel. I look at 100% wood flatbeds the same way I look at PVC headache racks, and I curse Home Depot for their existence...
Since you didn't use pressure treated, you should pick up a can of deck stain & sealer and roll the whole thing with it. Otherwise that wood's going to go straight to hell when the rainy season hits. It'll also darken it up, keep it from getting shredded when you put anything on there, and make it look 1000x better.
Worst case if you don't want to lift the bumper to match, use a piece of 1x8 or 1x10 bolted on the back to fill the gap.
That looks good, I agree with the census here though. I used treated wood and framed the edges and cross supports with angle iron. The diamond plate aluminum I used I bought at my scrap yard. Word of wisdom though, that aluminum is HARD to cut. If you don't have a plasma cutter, the only thing you can use is a carbide tipped framing blade on a skill saw. Plan on using about four or five of them though....
I would have rather used steel and painted it. I think that would have been easier.
I still haven't gotten my headache rack built or my fuel fill tubes relocated right.
It'll get something cause i want stacks...
Harsh toke Dude...
Since you didn't use pressure treated, you should pick up a can of deck stain & sealer and roll the whole thing with it. Otherwise the that wood's going to go straight to hell when the rainy season hits. It'll also darken it up, keep it from getting shredded when you put anything on there, and make it look 1000x better.
The 4x4's are treated, but the rest will get deck sealer in the near future.
See above. That bumper is going to go away...
Harsh toke Dude...
I was looking at hitches and all the ones i saw V5 rated had 1/4" steel sides... And the plate that was in the bed is 1/4"...
Ihateminimumwage (me too), would you feel better if i trimmed the sides and back with 3"x3"x1/8" angle iron?
I need something to put stake pockets on anyway...
The original plan was a steel frame with 3/4" plywood decking, but i did this because of money limits... The hybrid bed may still get built someday...
Maybe you're planning to put fenders on there, and box sides? I did that with my Toyota years ago. got some fenders cheap (I think they were for utility trailers). Got 4 of them and doubled them up/welded together 2 on each side for required width. Then just cut a square cutout on y our wood bed, cram the fenders up in there and lag screw them in. It felt kind of mickeymouse when I was doing it but it's been tough and ran that way a long time with no trouble. Not sure if the Ford would need the suspension travel that my yota did, though. I also used P/T wood and framed up box sides so I could put on my stock canopy and boat rack.
I like trucks like this....
Either you had really really cheap blades or you didn't use any form of lubrication/coolant. We cut aluminum everyday at work, including pre anodized 6060 T6 aircraft aluminum on a chop saw with an $80 carbide tipped blade. I send that blade out about twice a year to be sharpened and we cut a LOT of material on it. The best lubricant/coolant to use is good ol wd40, just a shot of it right on the teeth every so often will keep the aluminum from welding itself to the carbide tips and cause the blade to go dull. We use a table saw in the same fashion for cutting bigger sheets.
Yeah Warr....I had REALLY cheap blades.....no lube.....
We had no clue what we were doing....
I tried sawsall blades of all types but no lube. I wondered if the poly in the aluminum makes a difference?
It's funny, I work on the other side of metal so I know what type of aluminum and other non ferrous metals are but no clue how to work with them.
Thanks for the tip man....Still have a lot of cutting to do on this thing....
Frame that thing out and install stake pockets . No real point in a flatbed without options to add sides or have tie down points available when need be...
Sounds like you've laid out your plans for it, and it should be a good solid flatbed when it's done.
I'll never take back my stance on Home Depot, and the abominations it provides people the supplies to create...
