Wire and Cable Management
I use these guys, they are geared for wire loom maintenance, really good price, decent shipping.
https://www.clipsandfasteners.com/wi...clips-s/78.htm
I love the expandable braided loom to run wire bundles. I prefer the closed loom you need to feed the wire through vs the type you wrap around the wire, but they both work really well to stop any wire abrasion. Plus they look like they belong there and can really help to hide the wiring. I just put a stereo system in my DD and if you didn't know what you were looking for, you couldn't tell I have any non factory wiring in the car.
Oh yeah, and zip ties. Lots of zip ties in various sizes.
I agree on both counts speedfreak. I’ve used the braided loom and the split braided loom extensively to make things look more OEM.
What at do you do on the ends of the braided loom to keep it from fraying over time? I’ve been putting a small section of heat shrink (1/2 over the loom, 1/2 the length over the wires) on the ends. It looks ok but just curious if there’s a better way.
Thanks for the tips.
I usually just use 3M electrical tape the same way, half and half, mainly cause it matches the factory harnesses . As long as you don't tension it on the last few wraps or leave greasy fingerprints on the underlying layer, it usually won't unravel...... usually. The shrink wrap is probably better overall cause there's no chance of it coming off.
