DTC P2102?
on
Are you sure it's 2102? I'm looking in the manual and don't see that code.
But I did find this doing a google search..
When you say Fail Safe Mode did it do this?
Note: Not all vehicles equipped with a cylinder head temperature (CHT) sensor has the fail-safe cooling strategy.
The fail-safe cooling strategy is activated by the PCM only in the event that an overheating condition has been identified. This strategy provides engine temperature control when the cylinder head temperature exceeds certain limits. The cylinder head temperature is measured by the CHT sensor. For additional information about the CHT sensor, refer to Engine Control Components in this section.
A cooling system failure such as low coolant or coolant loss could cause an overheating condition. As a result, damage to major engine components could occur. Along with a CHT sensor, the fail-safe cooling strategy is used to prevent damage by allowing air cooling of the engine. This strategy allows the vehicle to be driven safely for a short time with some loss of performance when a overheat condition exist.
Engine temperature is controlled by varying and alternating the number of disabled fuel injectors. This allows all cylinders to cool. When the fuel injectors are disabled, their respective cylinders work as air pumps, and this air is used to cool the cylinders. The more fuel injectors that are disabled, the cooler the engine runs, but the engine has less power.
A wide open throttle (WOT) delay is incorporated if the CHT temperature is exceeded during WOT operation. At WOT, the injectors function for a limited amount of time allowing the customer to complete a passing maneuver.
Before injectors are disabled, the fail-safe cooling strategy alerts the customer to a cooling system problem by moving the instrument cluster temperature gauge to the hot zone and a PCM DTC P1285 is set. Depending on the vehicle, other indicators, such as an audible chime or warning lamp, can be used to alert the customer of fail-safe cooling. If overheating continues, the strategy begins to disable the fuel injectors, a DTC P1299 is stored in the PCM memory, and a malfunction indicator lamp (MIL) illuminates. If the overheating condition continues and a critical temperature is reached, all fuel injectors are turned off and the engine is disabled.
Or was the wrench indicator on? If so. then it was this...
Electronic throttle control (if equipped): Illuminates when the engine has defaulted to a ’limp-home’ operation. Report the
fault to a dealer at the earliest opportunity. On vehicles equipped with a message center, “ENGINE FAILSAFE
MODE” will be displayed, refer to Message Center in the manual.
This mode is different then the cooling failsafe mode.
Please give us some additional info so we can help.
DTC P2102 THROTTLE ACTUATOR CONTROL MOTOR CIRCUIT LOW
What that means, I don't know.
Or was the code...
Or was the code...
<TABLE border=1 cellSpacing=0 cellPadding=3><CAPTION>P2122 - Throttle/Pedal Position Sensor/Switch D Circuit Low </CAPTION><TBODY><TR><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH><TH vAlign=bottom align=middle></TH></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Description: </TD><TD style="BORDER-LEFT: medium none" vAlign=top colSpan=4 align=left>The accelerator pedal position (APP) sensor 1 is out of self-test range low. </TD></TR><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Possible Causes: </TD><TD style="BORDER-LEFT: medium none" vAlign=top colSpan=4 align=left>
- APP sensor harness shorted to ground
- Damaged APP sensor
I'm 100% sure it was 2102, I've had it so many times I can't miss it. There are no other codes thrown when this happens, and the words "Engine Failsafe Mode" on the dash are hard to miss. It is not the Check Engine or wrench. The engine coolant temp stays consistent at 190F when running, and the temp gauge never pegs hot. Clearing the code with my Edge programmer works. I get the code wether the Edge is connected or not, and if connected I get it while running in mode 0 (i.e. stock). Multiple dealers have found no issues and none has known anything about a 2102 code.
on
It makes it a little easier to suggest a possible solution when you provide more information....
Per the manual engine Failsafe Mode is NOT the cooling failsafe mode. It is in reference to the throttle control actuator.
From my previous post...
Since you have an edge. I would return the ECM to stock. Not the stock Edge program, but the OEM stock program. Then remove the battery cable to clear the ECM memory. Then drive it and see what happens.
This is about the only way to eliminate the Edge and its programs as a possible cause of this problem. If the dealer does not know what the code is then it may be something induced by the Edge.
And at this point, you need to elimate the Edge as the possible problem. Or the Edge could be masking the actual issue.
Take it back to OEM stock and post what happens.
on
You can do a google search on the code, but the responses for it are for Toyota vehicles.
Nabors
25
10-28-2020 02:53 PM
waystro
04-10-2013 11:43 PM
