ECONOLINE HELP
ECONOLINE HELP
I am looking at an old Ford Econoline truck. The VIN data plate is missing from the drivers door. The title states the VIN as "E10TH457496" and the year as 1967. Can anyone decipher and/or confirm the VIN? Is there any other "accessible specific" locations they stamped the VIN on these trucks? Thank you for any and all help.....
E10 = E100 Pickup.
T = 170 1V I-6.
H = Lorain OH Assembly Plant.
457496 = 1964 assembled August 1963.
Since you asked the question (in another thread) where the hidden VIN is located and received an answer where to look...here is more info.
By the VIN, this cannot be a 1967, because the 1967 serial number range is: A00,000 thru B99,999.
It cannot be a 1966: 732,000 thru 913,999 or a 1965: 580,001 thru 731,999 either.
1964 serial number range: 445,001 thru 580,000.
ECONOLINE HELP NEEDED
Thank you very much for the information! As you can tell I am new to the site and I posted my initial question in the wrong area. As far as the VIN being on a bracket next to the tailight, do you remove the tailight assembly to see it or look from underneath the bed of the truck? Thank you.
The brace is the metal brace that goes from the outer panel at an angle to the truck box endgate frame or door frame of a van. The number is usully stamped on it facing inwards where you can easily see it if not covered by paneling or stuff. If you P.M. me with an email address. I have a pic of one to show you where to look.
It usually is on the left one, but they are at times found on the rightside also.
This brace goes across behind the taillight.
Pictures
If you don't mind, some pictures would be fine. My email address is: wdoublej@gmail.com. Thank you.
motor-officer
motor-officer
Oz Econoline
09-07-2014 01:53 AM
SwampyBull
07-15-2012 11:37 PM
spartan986
01-17-2011 08:44 AM
Imperial Designs
04-15-2003 06:28 PM
