Bedplate resealed, still leaking oil...now what?!
Dealer pulled my engine and resealed the bedplate about 3-4 weeks ago. Crawled up under the truck yesterday(I do about once a month) low and behold...OIL! Called service manager on his cell, yes I have his cell #, he recognized my voice too (tell me how much that sux), he said to bring it in tuesday they would put it in the air and check where it's leaking from, he stated they put dye in the oil when they changed the oil when motor was out. Question is what's the next step, assuming it's the bedplate again? Shortblock...if so it's definately getting studs this time. Never seen an oil leak that can't be fixed on a motor w/54K on it.
I've had a similar thing goin pretty much since new on my 05. Never any droplets just some residue in the rear main seal area.
It's the hanging drop. However it was falling on the ground previously and it all started with the hanging drop. Seems like it would drip when the engine got really hot, like towing in 90+ degree conditions. I've made 5 trips now to the dealer trying to get this ironed out so it's become kind of a vendetta now.
Based on the responses I have received I don't think I asked my question clearly. What is the next step in the "repair chain" for the dealer to follow to remedy the situation? Is it a Short block, bed plate gasket again, etc. I applogize for my lack of clarity. BTW I have already paid the deductible twice for this leak...fun times at Stivers Ford.
3 to 4 weeks ago and its leaking again? Sounds like they didn't do it right the first time. Missed some silicone on the front/rear cover joints or something.
I have done a few of these and its a poor design. What I have done is put a light coating of that gray silicone that is used to seal the front/rear cover joints on the bedplate gaskets. This makes just a little better seal and keeps that "seep" from appearing. So far I have had good luck with it.
Make sure this leak isn't being mistaken for a cam sensor o-ring. The outermost o-ring likes to give up and then the oil runs down the bedplate seam a little.
Its in the dealers hands to fix this though, so all you have to worry about is how much sweet time they take before you get to drive a leak free truck. I don't about other dealers but our Ford dealer is horrible at turning around a vehicle to the customer.
Edit: I don't think the dealer would install a new engine. I would be cheaper to pay labor to repair again. You'll have to wait for them to diag the problem more closely to know for sure what they need to do. I don't know how much control you really have in the matter if its warranty.
solaratomic -
They put dye in it, so hopefully it can more easily be resolved now.
BTW they have replaced the cam sensor o-ring and the glow plug harnesses twice
We had a fire equipment service guy come by the other day driving a 6.0, he highly recommended a local mechcanic/dealer to me saying he/they had taken very good care of his truck. It's a little further to drive but based on this information this may be the way to go.
I had never thought of anaerobic sealer. That would work well. Thing I was always concerned about using anything on the surfaces is the potential for main bearing clearances to change. Anaerobic is so thin that it would never make a difference. The gray silicone coating the gasket works well too though.
Funny that International never had a remedy of any kind for this leak. Unless they just changed the service manual for bedplate install and didn't tell anyone they did. I haven't done one in about a year.
