Nylon spacer at radius arm keeps breaking
Old 07-21-2010, 11:23 PM
stevorino's Avatar
stevorino
stevorino is offline
I replaced the radius arm bushings on my truck about a year and a half ago and about 6 months later I found that the nylon spacer on the driver's side cracked in half and only half remained on the truck so I replaced it (under warranty) and I found the same thing again today. I torqued it to factory specs and the passenger's side is fine. What gives?
Old 07-22-2010, 09:03 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Keep us informed on what happens. I just finished replacing all of my suspension bushings with the Energy Suspension Polyurethane ones. I will be keeping my eye on them now.
Old 07-25-2010, 11:20 PM
stevorino's Avatar
stevorino
Mine are Moog radius arm bushings and Energy Suspension axle pivot bushings. I wanted a little softer feel on the radius arms and a more resistant pivot bushing but it looks like one of the pivot bushings is worn out already anyway.
Old 06-16-2013, 06:29 PM
hayden01's Avatar
hayden01
hayden01 is offline
Oh how wonderful, I am looking into getting axle pivot bushings and leaf spring bushings from Energy Suspension and radius arm bushings from Moog. ... I sure hope its just a fluke with your bushings wearing out prematurely... that would tick me off spending all that money and then have them fall apart.
Old 06-17-2013, 06:34 AM
JWA's Avatar
JWA
JWA is offline
Received 1,410 Likes on 1,112 Posts
I'm also running both Prothane & Energy Suspension bushings in my E250's and not a single issue with either so far---been in excess of 70K miles too.
I never knew hard nylon was used for suspension parts. The urethane formula for radius arm and axle pivot bushings is hard enough of its application, better than the stock offerings.
coolfeet
03-12-2016 10:19 AM
Damifiknow
04-18-2015 02:35 PM
Backflip164
12-02-2014 02:45 PM
JJS72XLT
12-02-2012 06:29 PM
biederboat
1978 - 1996 Big Bronco
11-28-2005 08:43 AM
Quick Reply: Nylon spacer at radius arm keeps breaking
