King Pins?
Old Apr 17, 2015 | 03:59 PM
Damifiknow's Avatar
Damifiknow
King Pins?
Well drivers side needs kings replaced. Should I use metal or nylon bushings?
Nylon is about 10 bucks more. I'll spend the money but what is better? Opinions, tips, and tricks are all welcome.
Old Apr 17, 2015 | 05:42 PM
HIO Silver's Avatar
HIO Silver
Metal all the way... Nylon (or whatever plastic polymer it is) starts to loosen up around 40K miles. Granted ya might not have the truck that long but a little effort now goes farther down the road.
Old Apr 18, 2015 | 10:11 AM
hivoltj's Avatar
hivoltj
The metal ones will end up costing more as they'll have to be reamed to size. Take your knuckles with a king pin set to an old school or big truck alignment shop and drop them off.R..
Old Apr 18, 2015 | 11:02 AM
HIO Silver's Avatar
HIO Silver
A machine shop that is worth its salt can ream to size. If they cannot, then they probably should not have "machine" in their business name.
Old Apr 18, 2015 | 01:04 PM
ultraranger's Avatar
ultraranger
If one side needs replacing, it only makes sense to do BOTH sides.
Plastic bushings don't require reaming. The down side is they don't have near the service life of bronze bushings. Keep the kingpins greased and the bronze bushings will easily last 100,000 miles or more.
A local machine shop had loaned me the reamers (for free) for me to do my own bushings. I had never done this before but, it doesn't require being an Einstein to figure it out. I used a Moog kingpin set with .859" (55/64") pins and bronze bushings. Part number 8540B.
'77 F100 I-beams/discs I swapped onto my '69 F100.
Old Apr 18, 2015 | 01:08 PM
greenmachine55's Avatar
greenmachine55
Metal. Just had mine replaced a few months ago with the tie rods!
Old Apr 18, 2015 | 02:35 PM
earthquake68's Avatar
earthquake68
I just did bronze bushings in the '73. I honed the bushings to size. That way you can sneak up on it and set vertical clearance down to the .001 of an inch. I set them at .003" (.006" bigger bore in the bushing than the diameter of the pin) Zero play in the front end.
red-bulli-69
May 29, 2019 05:02 PM
egg collector
Oct 9, 2013 08:51 PM
brownfoot
May 3, 2010 01:54 AM
Redmanbob
Jan 25, 2009 09:32 PM
towtruck1
Aug 2, 2006 03:37 PM
