side effect of disconneting egr valve
Old 11-26-2011, 06:14 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
Originally Posted by JerseySticks
You guys are probably going to think I'm going crazy or something, but I did the EGR delete on my 06 F-250 6.0 and my dash lights no longer function. Any thoughts?
Yepp, way unrelated.
I replaced my ipr yesterday and lost a few lights in my gauge cluster.
A little bang on the dash board fixed em up
Brighter than ever
  #197
Old 11-26-2011, 08:44 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Brighter than ever
I thought it was a bang on the windshield Tyler?
  #198
Old 11-27-2011, 08:17 PM
vlietracer64's Avatar
vlietracer64
vlietracer64 is offline
I have a first coast diesel egr delete which has the egr opening in intake welded shut. i currently have the egr plugged in and zip tied up, anyone know if i can cut the bottom off the egr so i can bolt it over the welded plug and have it secure and look a littler better?
  #199
Old 12-04-2011, 07:53 AM
BLK-PRL's Avatar
BLK-PRL
BLK-PRL is offline
Ok, so it seems as if the EGR valve is acting up again, and after reading through some great information, I have one question... seeing as there are benifits to leaving the EGR hooked up, couldn't i simply cut the EGR valve stem off and weld or fuse the valves shut so no gas recircs throught the cooler?
  #200
Old 12-04-2011, 08:47 AM
2006powerstroke90
Ahh, LOL....Yes, it was that too
  #201
Old 02-17-2012, 12:00 PM
eh76's Avatar
eh76
eh76 is offline
Read this entire thread and am now more confused than ever.Closest thing I am to a mechanic is knowing 1 or 2. I have an 04 F250 Supercrew with 32,000 miles on it. Yeah I know I need to drive it more. It doesn't get driven around town. Minumum trip is 50 miles one way and I don't baby it. No issues so far other then when it was brand new the turbo had a carbon buildup and had to be cleaned under warranty. I don't let this truck idle any more than needed to warm up before I leave.
I was referred to this thread by another member on another older thread. On that one they were talking about unplugging the EGR. My truck is bone stock. The software was updated last summer, so if I am correct that update eliminates the throttle plate function. I unplugged my EGR, go the 2 basic codes, but no CEL on. Any issues I need to be aware of?
I would like to do the mods you guys all talk about, but that will be a while as I have to have someone do it.
  #202
Old 12-31-2013, 08:27 AM
gtmustang00's Avatar
gtmustang00
gtmustang00 is offline
I read all 14 pages. What i am understanding is on my 06 6.0 i will have to put the egr back in and plugged in, and i will have to get a program to get rid of the check engine light for egr insufficient flow. Correct?
  #203
Old 12-31-2013, 12:13 PM
figurhead's Avatar
figurhead
figurhead is offline
Yes. That is my understanding; 2003 trucks shows no CEL with the EGR valve removed, all other years must have it physically installed, electrically plugged in & deleted in a custom tune (software). Even then there may be some issues.
Here is my experience: I have a 2003 F350, and installed a full egr cooler delete. When I unplugged the EGR valve itself, regardless of my SCT X3 custom tune (which deleted it from the tune), the fan would not run normally and the engine would overheat. Note, I have never had a CEL come on; regardless of the truck setup (EGR Cooler delete, EGR unplugged, EGR plugged in, etc). I think it's a 2003 thing. But there were codes shown related to the unplugged EGR valve when I scanned the truck with the AutoEnginuity with the Enhanced Ford software. With the EGR valve plugged in, even with the full egr cooler delete (thus, no egr cooler air flow), no codes of any sort show up.
I like the look of the blue anodized blockoff plate and no EGR valve, it's just that the cooling system wouldn't run right with the EGR Valve removed. Having the EGR Valve in place looks more legit and I have passed two CA smog tests even with the full egr cooler delete and a heavily modified 6.0l.
  #204
Old 12-31-2013, 12:55 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
04's don't need the valve either.
  #205
Old 12-31-2013, 12:58 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I have had the stock tune and EGR delete with no CEL or pending codes.
Josh
  #206
Old 12-31-2013, 04:16 PM
gtmustang00
Josh
What is your pcm strategy? Mine is a 2006 with
VXCF5H5
TQCK0T5
  #207
Old 07-15-2014, 09:40 AM
Bullitt390's Avatar
Bullitt390
VXCF5H5
TQCK0T5
To help update:
My 06 has VXCF4HH strategy
Josh
  #208
Old 07-15-2014, 06:03 PM
cheezit's Avatar
cheezit
cheezit is offline
Josh I was only able to varify the concern with vxcf9. Never had a code in my either, just wasnt able to activate the cooling fan correctly with ids
  #209
Old 07-15-2014, 06:41 PM
Bullitt390's Avatar
Bullitt390
So, at high idle with fan commanded to 100% duty it should turn approximately 2800 rpm with the EGR valve plugged in?
Unplugged/disconnected EGR valve the max fan RPM was only around 900 @ high idle?
I could try an experiment this weekend as I believe our remaining 2005 F550 at work has either the VXCF5 or VXCF7 strategy, whereas mine is VXCF4.
Josh
  #210
Old 07-15-2014, 07:17 PM
cheezit's Avatar
cheezit
cheezit is offline
Without going back to the beginning of 14 pages, those numbers seem correct?
Testing a cooling fan per the wsm test it at 2500 rpm, a working fan clutch should exceed 2800 rpm with 100% fanvar#.
Its what both myself and matty had found to be true at about the same time. I did question hotline about a p0405 and fan clutch operation at one point and got the standard awnser of we dont know.
Quick Reply: side effect of disconneting egr valve
