Air Conditioner freezing up
I recently recharged my air conditioner. I made sure to stay within the suggested pressures and it does work well now however it freezes up after 10-20 minutes. This gets to the point that the fan barely blows any air at all but the air is still cold. You can visably see frost building up on the ac lines and the evaporator. I have checked the evaporator drain and it does not appear to be plugged. When the ac is running I cannot hear the clutch kicking in and out however if you do it manually you can hear it. Just wondering if there are any sensors or anything else that I should check. If anyone can help with this, pictures and/or details would be appreciated.
Thanks for the reply, its a 2001 Ford Escape XLT 3.0 V6. I have now changed the cycling switch and it didn't seem to make any difference. The low side AC lines still frost right up in about 10 mins and the AC itself seems to slow down after about 20 mins. I also rechecked the charge and it is up to almost the max level. Also I checked the evaporator drain and it seems to be draining well. Not sure what else it could be, any suggestions. Thanks
Get a manifold gauge set on there and measure your pressures under the factory-prescribed test conditions. Without pressure readings and knowing what the ambient conditions are, it isn't going to be possible to remotely diagnose...
dpilot83
1999 to 2016 Super Duty
03-24-2017 04:34 PM
rmarquet
02-29-2016 04:31 PM
rla337
08-09-2013 12:54 PM
TampaDave
05-13-2012 01:49 PM
rick
06-06-1999 06:15 PM
94, ac, air, airconditioner, bronco, conditioning, duty, evaporator, ford, freezing, line, lines, super, truck, up
