A/C Question ' 78 w/factory A/C - Ford Truck Enthusiasts Forums
Old 06-02-1999, 02:49 PM
rick's Avatar
rick
rick is offline
rick is starting off with a positive reputation.
My A/C sometimes freezes up at the lines on the firewall where they go into the air box (evaporator) particularly the high side line the one that has a valve in it I don't know the name of the valve, I know the system is fully charged, and blows ice cubes out of the vents until this line/valve freezes up, any ideas?? THANKS!!
Old 06-05-1999, 12:49 PM
R P
R P is offline
R P is starting off with a positive reputation.
You may have some moisture in the system that will freeze up and cause a restriction in these lines. To cure this you may have to evacuate and recharge the system. Or the evaporator is freezing up (particularily in moist climates)so add a little heat on your temp control, for a few minutes, to try and keep the evaporator free from icing up and see if you Ice cubes return to flying out the vents.if the later helps you may just have a moisture draining problem in the evap box.
Old 06-06-1999, 06:15 PM
rick's Avatar
rick
rick is offline
pitt79
06-13-2017 07:58 PM
mjr46
15
08-10-2016 07:58 PM
BBslider001
17
07-16-2015 05:06 PM
maximusfd
01-21-2014 09:53 PM
rla337
08-09-2013 12:54 PM
Quick Reply: A/C Question ' 78 w/factory A/C
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
