Pump the brakes to get a firm pedal?
After finally replacing all the brakes lines and hoses and a right caliper, we went to bleed the brakes and sorta ran out of fluid. We had about 1/3 of the back reservoir full when done. The first push of the pedal, it gets pretty firm right around the floor but but after about 3 pumps it gets nice a firm about where a regular pedal should get firm. My question is, is it a bad MS or because i dont have enough fluid in the MS?
I have found that pushing the pedal down very slowly, holding it there, and gently releasing it can be effective at pushing through those last few air bubbles. Pumping the pedal too fast can create turbulence and just move the bubbles around. The order you went in is correct.
It's also possible that one of the fittings isn't sealing properly and is letting in tiny amounts of air that are hard to see.
Also, give this a read: https://www.ford-trucks.com/forums/8...ml#post8072800
You're technically supposed to pull out the proportioning valve pin when bleeding the front brakes. A lot of people don't do it and it's not always necessary, but it's technically the correct way to do it.
Another thing to check is to make sure the drum brakes are properly adjusted. Even though they have automatic adjusters sometimes these freeze up and don't work. Drums with too much clearance between the shoes and drums can cause the same symptoms.
The valve is a small pin that is located on the front of the proportioning valve. It should be pulled out slightly and clipped so it doesn't pull back in while you bleed the brakes. When done bleeding take the clip off.
Crack the bleeder every time it hits the floor. Close it back up before your helper releases the pedal.
Fords412
16
11-17-2016 02:31 PM
timbersteel
04-25-2016 11:11 PM
ericjacobsen3
13
08-29-2014 02:18 PM
Truckmano5
09-06-2005 11:20 AM
