Fuel Pump Eccentric?
The fuel pump eccentric pushes the arm up and down on a mechanical fuel pump . Some engines were built for use with mechanical fuel pumps but never used with them thus having this eccentric in them and not needed.
If yours has EFI you don't need an eccentric but if you remove it you you have to replace it with a thick washer .
Something needs to keep the camshaft from moving out of position. It might be that the fuel pump eccentric prevents it from moving out of position by rubbing on the timing chain cover.
Yes, read the directions (Service Manual is best direction), from beginning to end, understand the directions, then follow the directions.
Or do what I do, do it twice, sometimes thrice.
tater_51
02-22-2023 11:59 AM
tbakko
10-05-2012 10:13 AM
fishin1976
49
09-22-2003 08:53 PM
