Fuel Pump Eccentric No Alignment Pin Hole
Old Oct 4, 2012 | 09:30 PM
tbakko's Avatar
tbakko
I have a 302 that I pulled out of an 89 1/2t Econoline van. When I pulled the engine apart I found the fuel pump eccentric had no hole in it for a pin. I don' think this motor is original as I think it should be FI but it has a carb. & mechanical fuel pump. What keeps the eccentric from coming loose on the cam gear, will the timing gear bolt alone hold it?
Old Oct 5, 2012 | 10:13 AM
95e150CW's Avatar
95e150CW
89 econoline should be EEC-IV MPFI.
If there is no pin/hole on the timing gear, then that gear probably wasn't made to run a fuel pump. There might be a locating HOLE on the face of the cam gear, that the 2-part eccentric slots into with a tab.
An electric carb fuel pump is always an option... (i havent had awesome luck with those, always need to put a regulator on them).
speedwaypj
Aug 6, 2012 09:19 PM
1986F350witha7.3
Jun 7, 2011 07:18 PM
tater_51
WTB - Parts & other
Sep 8, 2010 02:07 AM
80demoace
Sep 13, 2007 10:32 AM
tommyleea
Oct 13, 2006 08:59 AM
