1978 - 1996 Big Bronco
charging problems
Old May 30, 2010 | 09:00 PM
vtjvt's Avatar
vtjvt
charging problems
A few weeks ago I did the 3g upgrade on my 90 bronco, today the volt gauge started bouncing back and forth and then stopped charging all together, I suspect the regulator is bad, is there a simple way to test it?? and are all 3g regulators the same? and lastly is there a good place online to buy one? my local checker wants $78 for it and autozone wants $45 but has to order one in.
Old May 31, 2010 | 08:50 PM
vtjvt's Avatar
vtjvt
Anyone???
I found one on ford fuel injections site, mabye I will just go ahead and order one.
Old May 31, 2010 | 09:18 PM
Encho's Avatar
Encho
The Southernmost Mod
Get the specified numbers and check what is yours doing before going out and buying anything. I thinks you most probably don't have something properly grounded and that's what's causing you these issues, try looking around the alternator. You could also check: The serpentine belt, a worn or dis-aligned one might not transfer enough energy to the alternator. The pulley on the alternator, is it working right? nothing feels loose?.
Old May 31, 2010 | 09:26 PM
vtjvt's Avatar
vtjvt
Everything looks and feels tight, Also has a new belt and tensinor, I am going to recheck all the wiring and connections when I get home from work tuesday. I went ahead and ordered a regulator, I figure with both my fords converted to the 3g setup having an extra couldn't hurt.
Old May 31, 2010 | 11:00 PM
Encho's Avatar
Encho
Having some extra spares isn't a problem i guess. I hope you find the cause soon, and hope it's an easy/cheap fix.
Old Jun 1, 2010 | 11:10 AM
hey172's Avatar
hey172
what is the 3g upgrade?
Old Jun 1, 2010 | 07:22 PM
vtjvt's Avatar
vtjvt
https://www.ford-trucks.com/forums/9...hlight=upgrade
read through this thread
