Fuel Filters - OEM or aftermarket ?
Have a look at this thread from the 6.0 tech folder sticky at the top of the page:
https://www.ford-trucks.com/forums/5...-look-for.html
Ford will void any remaining warranty if you did not use the proper filters (if you have any warranty remaining).
The aquabloc membrane was part of a patent for the fuel filters, so many (maybe all??) aftermarkets have not included them. The aquabloc is imprtant as it keeps water from reaching the injectors.
Other aftermarket fuel filters have shown to plug more easily and/or bypass when plugged. Both of which shorten the life of the injectors.
This topic gets me a TON of upset pm's. I frequently get acccused of blindly recommending Ford filters and sometimes my capability for independent thought and reason is questioned .
Just got a similar pm on TDS.
I really don't understand why people defend aftermarket filters so emotionally. It is almost like they are believing that these companies single handedly are saving us from some perceived overpriced thievery of the dealerships.
What makes the aftermarket filter companies more "noble" than the dealership? I wonder where the aftermarket companies get their filters made .............. actually no I don't!
Don't folks know that it is actually RACOR that I (we) are advocating (and not Ford or even International)?
Some of the most shady people I have met in the Industrial world are filter salesmen - quoting efficiency ratings, loading capabilities, micron filtration specs, graphs, charts, etc. All with a slant and part of the story kept secret.
Oh well, my personal pressure relief device just "re-seated", so ........ to each his/her own I guess.
Updated Part Number FD-4616
If you order an After Market filter, remember that Ford did a part change on the filter to a new one that has a new disign to keep water from passing through (leaking past the seat). I will try and get a picture of the new one..
See Link below
Ford 6.0 Liter Turbo Diesel Motorcraft FD-4616 Fuel/Water Seperator Filters(FD4616): Pick Up & Excursion-REPLACES MOTORCRAFT FD-4604-NEW UPDATED
SKU: FD-4616
See Link below
SKU: FD-4616
- Manufacturer: Motorcraft
- Ford number: 3C34-9N074-BA/3C3Z9N184CA
- Part Type: Fuel Filter/Water Seperator
- Fits Year(s): 2003-07
- Engine Type: 4.5 & 6.0 Liter
- Make: Ford
- Model(s): All Pick up trucks
- Shipping Details Details
- Specials & Discounts: Details
- Country Of Origin: USA
on
funny the most shady people Ive met are used car sales men, next to that would be the moc and bg sales people.
now here is my real world thing on this.
I have tested so many trucks for fuel pressure concerns its not funny. every truck I put an injector in to.
heres is what I have found. there is a company that makes a gold colored fuel filter with black ends. that filter has a restriction of 10 psi that when replaced with an oem filter the pressure returns to normal. these filter wer new that the customer had just went and installed.
ok oil filters we had a problem not long ago with a truck that needed 8 injectors. we removed them and took one apart. it was full of fuel filter material.
Ive done a few ipr valves do to failed oil filters as well.
now if you go over to the .org and know about trusteds oil cooler relocate kit that wasted an engine. hmmmm.
Messing around with filtration is something that is far more difficult than it appears.
The "art" is tightly controlled by the big filter boys like Parker/Racor who dominate the market.
The product appear to be simple to make.
Who have not took apart filters and muttered "I can do this".
Does it not appear that every hungry Chinese, Indian, Russian, German, etc. firm in the filters business have also done the same?
The fact is, it is ... not as easy as it appears to do the job.
It is just like the auto electronics business... components look very simple.
But just try to get a bill of materials, go out and buy the parts and build the identical part --- like the FICM ---- and see how far you get.
Now onto a personal story....
Many moons ago, I bought an air filter for a Ford 5.4 gasser... from FRAM.
This is Allied-Signal.
Not known to be a schlock.
Well, the filter failed.
Apparently I was not the only one that had the problem.
FRAM ended up paying for my repairs.
