What does 400 BBC mean?
Aaaaaaaaaand just to throw another monkey into the wrench, you could always throw in the concept of the Pontiac 400, which technically isn't a big or small block. Pontiac used the same block for engines from 326 to 455 cubic inches, so it's a somewhat universal block. They just changed the internals to determine the displacement.
Then again the Ford 400 isn't a big or small block either, as those terms are typically GM. Ford has families of engines (335, 385, FE, etc.), and the displacements fit into each family.
I mean, really, I'm not sure why there's any debate anymore regarding what a big block is versus a small block. We've all seen enough weird variations to know that these terms don't really have a lot of meaning anymore. There's a 443ci "small block" chevy, and a 348ci "big block" as well. When there's that much variation on the theme, the terms lose their meaning.
My 434 is still just a 335 series engine. It's not big block, it's not small block (although I'll probably tell people that it's a small block 434 just to confuse them ).
a true '396' is a rare bird, the first prototypes and Smokey Yunick's protested race engine were 396's... the production version is referred to as a '402' in most manuals
the Pontiac 326-455 blocks aren't identical/interchangeable but do share the same external dimensions. the internal casting's are very different, a 326 can't be bored to be a 455, and i believe the mains are different too. heads, intakes, oilpans & front covers all interchange though. aside from casting marks and stamped codes you can't tell what block you're looking at
i used to think that Olds was the same way but i guess they have 2 different deck heights for their blocks, heads interchange but intakes are block specific
Sam's1967
19
02-10-2020 10:56 AM
3twinridges
06-04-2017 05:12 PM
sheppard
38
10-19-2015 01:35 PM
