2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Wiring diagram
Old 05-15-2010, 10:15 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
Wiring diagram
I am ordering my lockpick to install an oem reverse camera on the oem navigation unit and I am needing some wiring help. I need to find out what color and where the reverse wire is. I assume it is a black/pink wire like the F150? I know I can tap into the reverse wire at a tail light, but the lockpick will be the one connected to the reverse wire, so i would prefer to use the reverse wire in the dash/kick panel. Does anyone happen to have this wiring diagram? Thanks for your help.
Old 05-16-2010, 07:02 AM
chuck s's Avatar
chuck s
chuck s is offline
Looks like gray and brown to the trailer connector. There's a fuse for it in the tow electrical box on top of the radiator shroud. Position 63 for the fuse.
Sorry I can't make this smaller and still readable.
-- Chuck
Old 06-01-2010, 03:29 PM
Cabinboy07's Avatar
Cabinboy07
Cabinboy07 is offline
Hey man, if you are electrically inclined, I would love to see you further mod your system to add a video feed in from your rear OEM DVD system (if you have one), to your OEM nav unit, probably through your lockpick. That is a task that I am thinking of taking on, but am less inclined electrically than mechanically. I would love for a little guidance in this area.
Old 06-02-2010, 07:23 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
I am not that smart or confident to try that on my expy.
Chuck S - I also found that reverse wire that is under the passenger side door sill. There are 2 green/brown wires that go back to the tailights.
My lockpick should be here this friday and I might try to install it in the next two weeks as i am going on a trip for a few days.
Old 06-03-2010, 07:26 PM
st381's Avatar
st381
st381 is offline
I am also doing a lockpick reverse camera install. Where are these reverse wires under the passenger door? Do you have a pic? I would love to hear about your install.
Here's a thread I started to describe my experience:
Coastal E Tech License Plate Rear Camera Install - Ford Truck Enthusiasts Forums
Old 06-04-2010, 12:04 PM
Cabinboy07's Avatar
Cabinboy07
From what I understand about the Lockpick, it comes with a harnes that plugs directly into the Nav harness. I don't think that you will need to track down the reverse wire at all. I would think that the Lockpick would come with detailed instructions, otherwise it really wouldn't be worth the $$$.
Old 06-04-2010, 12:44 PM
st381's Avatar
st381
st381 is offline
The harness is pre-built for all the radio controls but you have to hook one wire to the reverse wire in order to have the rear camera image appear automatically when the vehicle is placed in reverse. Hence, I need a good place to tap into the reverse wire.
Old 06-04-2010, 03:16 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
There is no reverse wire in the original stereo wiring so you have to tap into one.
The ford 360 lockpick works for all 06-09 FLM nav units so I doubt the instructions are that detailed on giving you a reverse wire for each FLM vehicle.
Old 06-17-2010, 12:37 PM
dm ford rebal's Avatar
dm ford rebal
dm ford rebal is offline
is their a web site 2 get a wire lay out
dannyboy11222
05-08-2015 07:02 AM
RedBoat
6.7L Power Stroke Diesel
62
06-20-2012 04:06 PM
RedBoat
1999 to 2016 Super Duty
12-13-2011 05:44 AM
lakedweller
04-20-2011 10:48 PM
machine62
15
12-19-2010 01:47 PM
Quick Reply: Wiring diagram
