seized 460
You don't know if it carried any oil pressure before. The truck is 33 years old if it doesn't knock while running then you got pretty close on the bearing(s). You are going to have to pull the pan to work on this anyway buy a $5.00 dollar plastigauge and find out what is going on. A new oil pump isn't all that expensive. Over the years my experience with 385 engines is that either the pump is bad or the cam bearings are are wore out. The 385 motors need a lot of volume.
ironman1977
65
12-27-2020 06:19 PM
frankosd
12-28-2017 02:05 PM
Highboy74
12-10-2010 11:49 PM
animalguy10
17
09-10-2007 12:53 AM
