94 ranger 2.3
Old 07-02-2010, 11:06 AM
beasley11's Avatar
beasley11
beasley11 is offline
94 ranger 2.3
the truck runs for about two seconds then stalls, the fuel system and electrical system seem to be ok, what is going on?
Old 07-03-2010, 10:46 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
What do you mean by "seems to be okay"? Have you done any tests? It sounds to me like low fuel pressure. Take the gas cap off and listen at the tank while someone turns the key on (not cranks the engine, just turns it to the "On" position. You should hear the fuel pump run for just second or two as it primes the engine. If you don't hear anything, check the Inertia Switch to see if it's been triggered, it should be located in the passenger side footwell right by the transmission tunnel sort of at the top edge of the carpet or floor mat, almost up under the dash. See if the button is sticking up or if you can depress it and click it back in.
If that's okay, then you need to look at the fuel pump fuse and the fuel pump relay. If those are good, then you probably have a bad pump.
If on the other hand you can hear it run when the key is first turned on, then you need to check fuel pressure to see if it's adequate. You can buy a cheap fuel pressure tester from Harbor Freight for about 15 bucks, it connects to the Schrader valve on the fuel rail. Turning the key on to prime the system should give you a minimum of about 35 PSI, if it's below that you may have a plugged fuel filter or a weak fuel pump.
DSparksF250
10-30-2016 10:47 PM
Mattias
1997-2006 Expedition & Navigator
01-08-2003 08:33 AM
TallPaul
Exhaust Systems
03-13-2002 10:13 PM
betsy
Exhaust Systems
03-02-2001 11:53 PM
persuader
Exhaust Systems
12-29-1999 01:26 PM
Quick Reply: 94 ranger 2.3
