I have a 05 X 4wd 6.0 EB. My problem is the Dome light does not come on when you open the door or the radio does not shut off when you open the door (no matter what door you open). Could it be the Delayed accessory relay in the fuse panel.
I had similar problems in the past. It was not consistant and I could temporarly clear it by pulling the #18 fuse. (marked for security module) but in a few days, here would be the problem again. End result was to have the security module replaced, expensive fix. Try a new delayed accessory relay, it's a cheap fix if it works.
