Wierd Problem?
Old May 11, 2010 | 11:23 AM
PORKWALL's Avatar
PORKWALL
Exclamation Wierd Problem?
I have a 05 X 4wd 6.0 EB. My problem is the Dome light does not come on when you open the door or the radio does not shut off when you open the door (no matter what door you open). Could it be the Delayed accessory relay in the fuse panel.
Thanks for any help
Chris
Old May 11, 2010 | 02:44 PM
96ozarker's Avatar
96ozarker
I had similar problems in the past. It was not consistant and I could temporarly clear it by pulling the #18 fuse. (marked for security module) but in a few days, here would be the problem again. End result was to have the security module replaced, expensive fix. Try a new delayed accessory relay, it's a cheap fix if it works.
Old May 11, 2010 | 03:11 PM
rosco_p_coltrane's Avatar
rosco_p_coltrane
Nevermind didn't absorb the whole question before posting a response...
Old May 11, 2010 | 03:36 PM
PORKWALL's Avatar
PORKWALL
Thanks for the help. i'll try that relay switch first.
sirandre007
Jul 21, 2024 12:48 AM
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
Rickx
Oct 12, 2011 06:43 PM
Marauder92V
21
Jun 11, 2011 09:06 PM
buckweber6
Dec 13, 2010 09:25 PM
