2000 Excursion Fuse #19 Keeps Blowing
Old 06-08-2009, 12:44 PM
sirandre007's Avatar
sirandre007
sirandre007 is offline
Fuse #19 is the Instrument Cluster, GEM Module, Overdrive Cancel Switch, PATS/PATS Transiever, Idle Validation Switch (Diesel only).
2000 Excursion V10
Would the wires in the running board have anything with this fuse? The supports are rusted and replacements are on my to fix list.
Of course this happens while my wife has the vehicle and I'm at work....
Old 06-08-2009, 01:14 PM
YellowSled's Avatar
YellowSled
YellowSled is offline
2000 Excursion V10
i love it when the wife calls to complain about something on one of the cars. Its the round wigglely things thats not working. lol... GL bro...
Old 06-08-2009, 11:43 PM
wallz's Avatar
wallz
wallz is offline
From reading the list of culprits, I would almost put money down on the dreaded overdrive switch. There have been documented cases of almost fires, and some have burned because of this faulty wiring at the end of the drive selector. I don't have a link for the post but will have a quick look and post back, or do a search.
Here is the link that talks about the problem. Post 31 has a picture of it.
https://www.ford-trucks.com/forums/7...uestion-3.html
Old 06-09-2009, 06:59 AM
sirandre007
Thanks, I will look at mine and update you on the progress.
Old 06-09-2009, 07:20 AM
cbradford's Avatar
cbradford
cbradford is offline
Maybe it's the wires rubbing through in the steering column, this has been a problem with many older Ex's it seems.
Old 06-09-2009, 09:44 AM
VaSheriff's Avatar
VaSheriff
VaSheriff is offline
duplicate post
Old 06-09-2009, 09:46 AM
VaSheriff's Avatar
VaSheriff
Fuse #19 keeps blowing .... is the Instrument Cluster....
This is the very first symptom I had when the Ford dealer discovered my exposed and worn wiring in the steering column. The symptoms get worse as the wiring harnesses moves around in the steering column and bare wires touch metal.
pbruckne
6.7L Power Stroke Diesel
17
01-05-2020 07:45 AM
BearMan54
1983 - 2012 Ranger & B-Series
33
02-13-2018 03:46 PM
old blue beast
08-05-2016 08:28 PM
Marauder92V
21
06-11-2011 09:06 PM
hurstcastle
16
01-06-2008 02:44 PM
Quick Reply: 2000 Excursion Fuse #19 Keeps Blowing
