66 falcon van help?
Old 05-05-2010, 02:51 PM
elmonto's Avatar
elmonto
elmonto is offline
66 falcon van help?
I just got a 66 falcon van in great condition and i need some help tryingto figure out the engine. Its an I6 with a tag that reads Y39206 or Y39306 the third to last number is smudged. The serial number in the door jam says E12TH247657, any help would be awesome.
Old 05-05-2010, 02:58 PM
jschira's Avatar
jschira
jschira is offline
Is the valve cover sort of square in x-section or more rounded?
Old 05-07-2010, 12:34 AM
66gpw's Avatar
66gpw
66gpw is offline
The T stands for a 170 engine. E12 is club van. H for Lorain plant. The others are sequential numbers representing manufactured date. These numbers say the van was built in 1962 .
The door could of been changed over the years and an old tag left on. If you look at the back inside of the van where there is a support member behind the taillights. One of these will have the original serial number and give you the proper info for engine and years. It is stampped right into the metal plate support. The other place to look is under the lip of the doghouse. This requires removing the doghouse and the sealant to the floor to see the serial number agin on the floor lip unde the doghouse.
Old 05-09-2010, 01:17 PM
elmonto's Avatar
elmonto
elmonto is offline
I was wrong, the registration says its a 61 van. Thanks for the help.
Old 05-10-2010, 06:37 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 66gpw
The T stands for a 170 engine. E12 is club van. H for Lorain plant. The others are sequential numbers representing the vehicles specific serial number.
These numbers say the van was built in 1962.
247657 = Assembled December 1961 as a 1962 model.
The typical problem that affects Ford Trucks, Econolines thru 1980:
People replaced damaged left doors with used doors. 99% of the time they did not transfer the original Warranty Plate over to the replaced door.
Falcon123
01-07-2017 10:47 AM
rustydicksimports
11-28-2014 11:33 AM
zombievan1966
05-23-2014 04:49 PM
kmft
07-14-2010 10:42 PM
tywhitaker
12-08-2007 08:09 PM
Quick Reply: 66 falcon van help?
