HAVE I SCREWED UP?
HAVE I SCREWED UP?
99 F250 LD 4X4
I purchased this truck about 9 months ago and have been slowly doing things that a truck with
200k miles needs. Shocks, balljoints,brakes, tires,
etc. I noticed that the diff. cover was a little damp but thought that I get around to changing the fluid and put another gasket on when I get the chance. I just had eye surgery and don't want to screw things up by doing to much. I noticed that I was getting that clunk when starting off from a dead stop sometimes. Read a service bulletin about greasing the slip yoke and that seems to have helped alot. But thought I would check the diff.
fluid. ( About time huh) I could feel it with my
finger. Well I thought I'll put a bottle of friction
modifier in just for the hell of it. Might even top
it off with some 75/140 mobile one full synthetic until I get around to a complete change. 1 bottle of modifier and 2 quarts of fluid later. It's still not
running out of the fill hole. Now I know it takes about 7 1/2 pints , plus the modifier after a change. My question is should the fluid level come
up to the bottom of the fill plug? Or does it hold
more than the 7 1/2 pints and I've crammed to much fluid in expecting it to come out the fill whole? Sorry for the long post
It seems you like most other people have the wrong idea of what friction modifier does.
1.Straight fluid allows the clutch discs to have max grip.
2. The modifier "lessens" the disc grip by making the fluid a bit more slick. This is how a measure of control is accomplished over the fluid friction ability.
The more friction modifier you put in the less the (traction lok) will work correctly. Not better!.
This is the same idea as for transmission fluid being formulated for a specific design. If you alter the fluid by the wrong additive or to much, the trans may not shift correctly and affect it's overall service life.
What you have for an issue besides that I could not say.
Never go by the old adage that if one dose is good two is better. Not so.
Good luck.
Good luck.
My Main Question Is:
I understand it only takes a small amount of modifier compared to fluid. I'm going to stick to OEM specs when I change the fluid completely.
I just wanted to make sure that I don't over fill the differential until then. So , my question is : Should I fill to the bottom of the fill plug , when on level ground? I know that is how I've done
every other vehicle I've owned in the past.
are you adding the lube thru the pipe plug that is about 1/2 way up on the side of the case or are you pouring it into the top thru the ABS port hole or something like that??
THe pipe plug on the side is correct. It should start flowing out when you get about 2-1/2 quarts of lube with the 1 bottle of friction modifier.
The fill plug is half way on the differential and I believe o'reilly autoparts has the gasket but not sure. It looks like my cover , although I'm not sure
if I have the 9.75 or the 10.25.
I can't make out the code on the tag and don't see it on the inside door panel. Also, what is the difference with the sterling?
Tnelson82
2004 - 2008 F150
10-18-2015 03:48 PM
49m47
03-25-2014 02:53 PM
Urban_Prisoner
1999 to 2016 Super Duty
01-17-2011 08:56 PM
RA81222
12-20-2006 09:21 AM
