fluctuating turbo boost
I have an 04 f250 with 130k on it. The boost pressure will sometimes jump up 4-5 psi with steady throttle or even if the cruise is on. It started last fast then seemed to go away with the cold here in MN now that it is warm again it has started doing it again. The RPMs dont go up nor does my speed change. I had to change the FICM recently was hoping that would maybe solve this problem also unfortunately it didnt. I am running spartan diesels agg. street tune but it still does it if I put it back to stock.
GSDogs
34
06-28-2022 09:25 PM
wcs69rat
01-10-2016 08:24 AM
08, 2003, 60, boost, diesel, f250, fluctuating, fluctuation, fluxuation, ford, intermitent, meter, reading, turbo, typical
