FYI trailer lights have fuse
hey just thought i would share this with everyone, my trailer signals and brake lights quite working but the running lights worked fine. leaving me two think signals were there too. anyway i was told that they werent working so i first checked the plug nothing... then i noticed there was a splice in the line with those crimp type connectors that join the 2 wires with a small metal knife like thing, they were a bit cooroded so i cut them out and re joined with 3m heatshrink crimp connectors with that rubber goo in them when heated up... still nothing so i called ford and they told me that there is a fuse under the hood for trailer signals so i looked it up in the manual and thats what it was a 25A fuse.. so when you have this problem check your fuses first !!
Koboss
Koboss
i know what your saying Camp i hate that too, but i couldnt leave those crappie connectors on there to run green gunk up the wires so i figured id better fix it best i could before my harness is green slime... and those 3m heat shrink connectors are pretty solid..
i would have never thought of a fuse on my own? thanks senix ive got that message before to.. funny
koboss
koboss
out here in the country, the gas stations still sell glass fuses!..
Sam
I lost my trailer tail lights a few times it took me forever the first three times as it was a totally different fuse than what was in the owners manual the last two times.
These are a couple in the fuse panel under the hood.
#33) 20 amp, back-up lamp relay
#42) 30 amp, trailer park lamp relay
Those took forever to find in the dark. I have since labeled them in the owners manual as to what they are.
My truck is a early job one build and have decided that Ford misprinted my owners manual. Hope those will help those who need them
I found this out several years ago doing diagnostics on a left turn problem on a disaster tool trailer. It took awhile, but I got kudos for finding it on an '04 shebby. Apparently several others had tried and it had even been in to the dealership. I can't believe it went to the dealer and they couldn't figure it out.
Sometimes one just has to break down and read the operator's manual. I think we often forget that's what they're there for.
Pigseye
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-29-2017 07:07 AM
Y2KW57
17
03-10-2016 08:59 AM
DemonRace6
07-27-2011 09:24 AM
koboss1
6.4L Power Stroke Diesel
02-16-2010 07:38 PM
