Mirror side marker light! How to change bulb???
Old 04-23-2010, 10:08 AM
F 250 6 liter's Avatar
F 250 6 liter
F 250 6 liter is offline
Hey in the book it does not tell me how to change the bulb in the amber lens on my mirrors. I have a 2003 F 250 and I cannot figure what the trick is to get the lens off to change the bulbs in it.
Anyone out there know or have delt with taking the lens out?
Thanks
Old 04-23-2010, 11:09 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
There's 4 little tabs that you need to undo to get the rear cover off of the mirror. Access them through the front by adjusting the mirror all the way in and all the way out. Once you get the cover off it's simple.
Old 04-25-2010, 07:15 PM
riggz's Avatar
riggz
riggz is offline
I don't think you can change the bulbs. They are LEDs on the 03-07. I thought it was just a direct swap for the whole unit.
Old 04-25-2010, 07:25 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Maybe a little more research is in order. Do you mean that you have to change the whole lamp assembly or the whole mirror? I'll check it out tomorrow to see for sure.
Old 04-25-2010, 07:32 PM
dschuffert's Avatar
dschuffert
dschuffert is offline
I replaced mine a couple of years ago. I broke one side on a tree limb. I had to buy the set. I bought the LED kit from Recon. They had great instructions on how to get the old assembly out of the mirror and how to put the new one in.
Old 04-25-2010, 07:44 PM
npccpartsman
Thanks "D". Did Recon offer a different color than the amber?
Old 04-25-2010, 07:55 PM
SteveBricks
I put Recon's "smoked" lenses on mine.
Old 04-25-2010, 07:57 PM
dschuffert's Avatar
dschuffert
Here's the link to their website: Recon Accessories: FORD SIDE Mirror Lenses
They show smoked and clear as being available for the lenses. All their LED's in this application are amber.
Old 04-26-2010, 12:37 PM
riggz's Avatar
riggz
riggz is offline
I meant the whole lamp assembly. From what I remember (I have 08 mirrors now) it was a complete unit that cost enough to justify purchasing a set from Recon. Of course you also have people who swap out to the Recon sets that sell their used ones for cheap.
The OP stated he wanted to know how to remove the lense to replace the bulb. That's why I questioned it.
Old 05-14-2010, 11:31 AM
n4aof's Avatar
n4aof
n4aof is offline
Used Mirror Lenses
I wish I could bump into someone with a set of lenses to fit a 2004 SuperDuty. All I need are the lenses, not the LEDs. My daughter tagged a mailbox with the passenger side mirror -- which I guess was better than hitting the garbage truck that pulled out in front of her. Didn't hurt anything else, but wiped out the amber lens on the mirror. So far as ford ir concerned that entire MIRROR is all or nothing.
Old 06-20-2012, 07:56 PM
Tumbleweed.NM's Avatar
Tumbleweed.NM
Tumbleweed.NM is offline
Easily replace Clearance Lights on Outside Mirror,F250
On a 2008, F250, To replace the Clearance Lights on the Mirrors:
1) Adjust the Glass Mirror all the way In.
2) Just past the edge is a 1" tab.
3) Push In on the Tab; the Clearance Light Unit should now be free.
4) Pull Out on the Unit and Untwist the Lamp Holders
5) replace the appropriate bulb. Goodluck..Don't pry on it with a screwdriver!
Old 08-07-2012, 01:44 PM
A-Loner Plumes Fox's Avatar
A-Loner Plumes Fox
A-Loner Plumes Fox is offline
i phoned in the local ford shop and the mechanic said to pry it open with a screw driver..grrrrrr lucky i kept on reading ffs..
Old 03-06-2013, 10:22 AM
WickidPissa's Avatar
WickidPissa
WickidPissa is offline
Just installed mine - super easy actually. Pictures:
Broken light (removed already):
Shows where to pry to remove (I find it easy to know WHAT you're prying before you pry):
Here's the Passenger's side, where to pry. It's tough to describe, but with an eye in there it makes sense:
Then once you get the housing off, you have this:
Just pinch these, and pop the light out:
Pop the new one in:
And just snap it all back in!
Old 03-06-2013, 04:15 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Well I was going to say check out this thread that I made last summer.
A heat gun helps to warm up the little wings that hold the lamp in place.
After you get the lamp removed the wings won't be as tight so heat them a little
bit and open them up to keep them in place.
https://www.ford-trucks.com/forums/1...or-covers.html
But I see it's been covered. The lamps are LED so you will have to do one of two things.
1. Take the lamp housing apart and try to fix it.
2. Buy a lamp assembly to put in. Check the yards for a broker mirror cover and
see if the lamps is good.
Sean
Old 03-06-2013, 06:29 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I hhad a broken one to
priced OEM and recon was Half the price Ford wanted for just one
Pretty easy desision and the smoke color lens looks great IMO
Quick Reply: Mirror side marker light! How to change bulb???
