How can an existing axle weight rating be increased (strengthened)?
<!-- message --> How can an existing axle weight rating be increased?
My front axle is right at the Dana rating with essentially no load in the back.
I presume steel is welded down the length of the axle tube to stiffen it.
I'm a Quigley 4x4 conversion van with their weldments on the axle tube to facilitate the conversion and I'd have to reverse-engineer those spring perches.
I recall seeing differential covers that had threaded bosses to take some sort of tie-rod.
But I don't think that arrangement increases GAWR.
And too, I don't have room for such bars due to the rear torsion bar and the front steering linkages.
I swung by the CAT Scales.
I topped off my fuel tank first and had my usual assortment in the front & back.
Dana capacity ratings includes the weight of the mounted tires.
The original tires were LT245/75R16E rated for 3,042 lbs. load.
I currently have load range H tires mounted on custom steel rims, the limiting factor here would be the rims limiting me to a 10,000 lbs. axle GAWR
The front Dana 60 axle is Dana rated for 4,500 lb.
The rear Dana 70U axle is Dana rated for 7,500 lb.
The van's door jamb stickers say GAWR Rear 6,084 lbs. which is the limit of the original tires @ 80 psi.
Detailed pictures are in my Gallery.
Thank you.
- Pictures?
- Web links?
Steer Axle 4480 lb. (As the aft of the axle tank is emptied more weight will transfer to the front axle.)
Rear Axle 4460 lb.
Gross Wt. 8940 lb. (Registered to factory limit of 9,600 lbs.)
Notes:Rear Axle 4460 lb.
Thank you.
The D60 front end typically maxes out at about 4500lbs. You can upgrade the ball joints and get a little more, but really there isn't a whole lot you can do. There is a D70 front, but it typically is set up for a dually, and I believe is a bit wider. Without knowing the specific weak spots, I would not add material to the axle. Depending on where the reinforcement stops, you may actually make it weaker and make the knuckles more likely to break.
I was watching one of those early weekend morning truck shows and on this one they were making a custom width Dana 60 to fit under a TJ. They also threw a bunch of upgrades at it to make it really strong. I looked up some prices later and this stuff isn't cheap, but I hope you didn't think it was going to be easy or cheap to beef up that axle.
Anyway they used Crane inner C's and a steering kit with larger knuckles. See this link: Poly Performance Inc.*::*Steering*::*Knuckles & Inner Cs*::*Dana 60 Knuckles & Inner Cs*::*Crane - Dana 60 Inner C - Jeep JK Synergy Suspension Systems, Fox Racing Shox, Beard, CTM, Johnny Joints®, Currie Enterprises, Edelbrock, Pit Bull Tires, Ramse
They also used some custom shafts with a CV-type joint instead of the standard u-joint. I don't know who made the axles though.
There was some serious money in this project and a lot of time. The guy showed how he put the axle together from scratch and it looked pretty involved.
Is your axle a ball joint or a kingpin axle? The kingpin axles are stronger.
I'm going to borrow a phrase and use it here: Strength costs money - how strong do you want it to be?
Andy, what does it entail to convert from ball joints to kingpins?
I'm thinking if I change the inner & outer Cs then I might be almost there.
Thanks for the Poly Performance link which drew my attention to the Crane hi Clearance inner & outer Cs.
The show was Xtreme 4x4 and it was episode 2010-08. Here's the link: Xtreme 4x4 - Episodes | PowerblockTV
I think you can buy episodes on DVD for a few bucks. Might be worth it if you are serious about this.
phlegm
21
04-24-2017 06:52 AM
DocB
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-17-2012 10:06 AM
bryan_johnson
11-04-2007 05:44 PM
8 Lugs
11-25-2005 09:15 AM
