Thinning Body Filler
Is there a way to thin body filler (Bondo, MicroLite, etc) for a final coat to fill sanding scratches? The last coat of drywall mud has a little water added to smooththe finish, so why not with filler.
Has anyone successfully tried this? Thinner, Mineral Spirits, etc???
Dont thin, doesnt like that much. Use polyester putty, or glazing compound. Currently we are using a product from Keystone, called Flo Putty (works good in cooler temps). It will fill all the pinholes that are inharent to bondo, if you take a blow gun and blow the bondo off and look closely you will see them, you dont need much of the floputty, just barely wipe it over the top then wipe most back off.
Sorry, if you put more/less hardner than recommended by the mfg'r to either make it cure slower/faster, you run the risk of it not setting properly and maybe cracking or something like that.
I would use spot puddy after primer to fill imperfections/pin holes.
That would be the easiest.
over and out
gseeders
BTclassics
22
05-31-2017 09:00 PM
norvillebob
10-03-2009 08:41 PM
