1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
04 f250 tow/haul switch issues??
Old 09-07-2013, 09:38 PM
lohpihowner's Avatar
lohpihowner
lohpihowner is offline
I recently purchased a 04 f250 with the 6.0l powerstroke. I drove it for about 3 weeks now, Ive put my trailer behind it with small loads and just today tried to use the tow/haul botton. When you go to pull out the tranny never shifts from first gear?? Its pulls and runs fine until you push the buttan and no shifting.........Any help much appreciated!!
Old 09-08-2013, 06:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
I've never seen this before. How high do the RPMs get without it shifting?
Old 09-08-2013, 08:24 AM
lohpihowner
I let out about 2000rpm's and give up and hit the button. That's with no load, just trying it out?
Old 09-08-2013, 08:38 AM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
Tow/haul raises the shift points considerably. This is most noticeable under light load conditions when you would normally expect the trans to shift a lot sooner than it will while in tow/haul. Keep feeding it throttle and see what happens. I'll bet you find that around 2500-2800 it shifts, which is normal.
Old 09-08-2013, 08:49 AM
lohpihowner
I never would have thought that!! The last ford diesel I had ('97 7.3) is a different animal then this 6.0. I just thought that was high?? THANK YOU GUYS!!!
Old 09-08-2013, 10:23 AM
Mark Kovalsky
Your old '97 didn't have a tow/haul mode. If had an overdrive disable mode. All that did was not allow it to shift to fourth gear. Tow/haul changes almost everything the transmission does.
Old 09-08-2013, 03:06 PM
lohpihowner
Mark I fell alittle dumb. I let a good friend of mine drive it after church today, told him about the issue. He had the drive it like it wasn't your attitude and it run up to around 2500rpm's and shifted quick. I guess I wasn't pushing it hard enough.....THANKS Justin
PokerMunkee
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
04-14-2016 06:06 PM
dgulledge
07-03-2015 02:54 PM
MoHeave
09-30-2011 02:11 PM
2012 SD Snowbuster
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-31-2008 12:54 PM
2003PSDF2504x4
09-23-2007 09:02 PM
Quick Reply: 04 f250 tow/haul switch issues??
