wierd front tire wear
on
I have noticed some unusual front tire wear on our 01 excursion 7.3L. It is a block type tread and the back of the block seems to be wearing down more then the front of the block. As you move your hand in a counter clockwise direction, your hand will drop as it goes from one block to the other. This wear seems to be across the full width of the tires, on both front ones. The rears seem to be flat going from block to block. Here are some picts (when I took the picts I had already rotated the tire so no the front one are on the back but on the same side of the rig).
here is the front tire with a block across the tread to show difference in hight between the tread blocks
here is the overall view of the front tire
here is a block across the rear tire tread
here is the view of the rear tire tread
I don't know if it is alignment of just the way it is going to wear but I need to hold off on an alignment until the my town goes through and graders for the first time this year to fill in the million of pot holes on my dirt road. Thanks.
Mine did that too. I took it to an alignment shop and was told I didn't need an alignment at all. I was advised to rotate the tires, but swap them side to side on the rear and things would even out. I was told the only issue was that I didn't rotate my tires often enough, but that the suspension on the truck was fine. So, I don't know if you rotate often or not, but you might try it. My tires, after about 3000+ miles are d*mned near evenly worn now. So, can't say the alignment shop knows what they are talking about, but it worked exactly as they said it would
on
That could be true Ace. We bought it last fall and the tires were practically new then. It probably has 8-10000 miles now. So I since I have the right front on the right rear and left front on the left rear, I should just swap the rears to opposite sides? Did the shop give a estimated number of miles for each rotation? 3000, 5000 or some other?
I too had the same issue, took it to the dealer and they said alignment was fine. But why would it constantly pull to the right? So I found a frame and alignment shop, he found the camber/caster was off, put in a different shim and no problems since. It's cheaper to have a reputable shop check it then it is to replace tires prematurely. I rotate every oil change now....anywhere from 5,000 to 7,500 depending on where or how hard I have been driving it. Will be getting 50,000 out of the TOYO M/T as long as I keep rotating. Also, don't think they should be rotated from side to side, always been told front to rear.
rotun, you're right about the front to back, however, my tires were badly worn. They were worse than the original posters tires. So, I was told if I rotate them, but then switch the rears they will wear back in to square, and they did. Also, it makes sense your camber/caster was off due to the lift. You can't lift a coil sprung, fixed control arm/radius arm vehicle without changing the caster.
So, going forward I'll rotate them front to back, but more often.
Wildstang, I was told that the tires I have need to be rotated more often than you might otherwise, and to rotate them every 3000 miles. My understanding is because I have "D" load range tires on a heavy truck. So, if it were "D" load range tires on a 1500 or something it'd probably be every 5000+ mile rotations, but on the Super Duty you tend to "need" rotations more often.
Again, what they advised worked. By the way, the shop was Les Schwab, which is a pretty big outfit and they certainly could have done an alignment and charged me appropriately but felt it was unneccessary.
The DR lift came with the cams, and was aligned post- lift, it was after driving with the lift for about 10000 miles it started to pull, he found the right side was out and replaced just that cam.
Did you keep the rears swapped after they squared out or just kept them on same side then rotate to front? Just curious in case I run into issues again.
+1 on the D range, E can go a little longer.
wildstang
26
09-18-2015 08:31 PM
wildstang
04-08-2014 06:19 AM
wildstang
07-16-2013 05:22 PM
pdombrowicki
09-14-2012 07:54 AM
