1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
BOTH P0420 AND P0430 CODES
Old 04-11-2010, 11:01 AM
prochamp's Avatar
prochamp
prochamp is offline
Hello all. I'm a new member. I just purchased a 2006 f-250 4x4 extended cab with a 5.4 triton. I bought this truck from the chicago area which is about 175 mile north of my home. After I bought the truck I got about 100 miles down the road and the check engine light came on. Im asuming they used a scan tool to clear the computer and get the light to go out. I did a good search before purchasing the truck and everything came up good, 2 owner, 50,000 miles, never been wrecked, etc. Payed $14,995 for the truck. Thought I got a good deal , now this. The engine seems to run perfect but I get both p0420 and p0430 codes. I just don't believe both coverters are going to take a crap at the same time, or o2 sensors. I dont here any exhaust leaks. What could be causing these codes to come up.
Old 04-11-2010, 11:22 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Well, it's one or more of the following three issues:
1. Bad Gas
2. Bad O2 Sensor(s)
3. Bad Catalytic Converter(s)
I would address the potential issues in the 1-2-3 order presented. BTW, welcome to FTE!
Old 04-11-2010, 01:19 PM
Rongold's Avatar
Rongold
Rongold is offline
Talking CODES 420 & 430
Both of your converters should be covered for 8 years or 80,000 miles by Ford. The oxygen sensors might be covered for 8/80 also--not sure.
RON
Old 04-11-2010, 01:53 PM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Yeah, take it to the dealer and make it their problem. The 8 year/80,000 mile warranty on emissions components applies even if you are not the original owner.
Old 04-11-2010, 02:19 PM
prochamp's Avatar
prochamp
prochamp is offline
Thanks for the help guys. I dind't realize I would be covered since I didn't buy the truck new. My 98 f150 had 180,000 on it and the check engine light had been on it since 125,000 was on the truck. It was the egr valve not opening propper, but the truck ran fine. Ive got a pretty good scan tool and I would just check it every so often to make sure any new codes had not acured. I bought this 2006 and it just bugs me that the check engine light is on with only 50,000 on the truck. I sold the 98 to my son and he wanted the f-150 fixed, he said the check engine light bugged him. I put a new EGR valve on it and the light has stayed out. The funny thing about my son, he had a worn out saturn and the check engine light has been on it for a couple years and it didn't bother him. Maybe its not just the f-250 has only 50,000 on it, but its just a new truck to me and I want it to be perfect. LOL
Old 04-11-2010, 05:41 PM
Furian's Avatar
Furian
Furian is offline
Is your F250's gross vehicle weight over 8,500 lbs? If so, then the emissions warranty is only 5 years/50,000 miles. See Page 12 in the link below.
http://www.motorcraftservice.com/pub.../06frdwa5e.pdf
Page 12
EMISSIONS DEFECT WARRANTY COVERAGE
During the warranty coverage period, Ford Motor Company warrants that:
• your vehicle or engine is designed, built, and equipped to meet - at
the time it is sold - the emissions regulations of the U.S. Environmental
Protection Agency (EPA).
• your vehicle or engine is free from defects in factory-supplied materials
or workmanship that could prevent it from conforming with applicable
EPA regulations.
• you will not be charged for diagnosis, repair, replacement, or adjustment
of defective emissions-related parts listed under What is Covered?
on pages 13-15.
The warranty coverage period for:
• Passenger cars, light duty trucks (vehicles with a GVWR of 8,500 pounds
or less
— 8 years or 80,000 miles (whichever occurs first) for catalytic converter,
powertrain control module, onboard emissions diagnostic
device, natural gas vehicle (NGV) module (Bi-fuel/CNG), electronic
emission control unit, and transmission control module;
— 3 years or 36,000 miles (whichever occurs first) for all other covered
parts.
• Heavy duty vehicles (vehicles with a gross vehicle weight over 8,500
pounds)
— 5 years or 100,000 miles (whichever occurs first) for covered diesel
engine parts;
— 5 years or 50,000 miles (whichever occurs first) for all other covered
parts.
See WHAT IS COVERED for list of covered parts.
EMISSIONS PERFORMANCE WARRANTY COVERAGE
Under Emissions Performance Warranty Coverage, Ford Motor Company
will repair, replace, or adjust - with no charge for labor, diagnosis, or
parts - any emissions control device or system, if you meet all of the following
conditions:
• You have maintained and operated your vehicle according to the instructions
on proper care in the Owner Guide, the Scheduled Maintenance
Guide, and this booklet.
• Your vehicle fails to conform, during the warranty coverage period, to
the applicable national EPA standards, as determined by an EPA approved
inspection and maintenance program.
• You are subject to a penalty or sanction under local, state, or federal
Old 04-11-2010, 05:49 PM
ke6zmy's Avatar
ke6zmy
ke6zmy is offline
P0420
Catalyst system below threshold (Bank 1)
P0430
Catalyst system below threshold (Bank 2)
Could be a sensor(s). May be a CAT(s). A scantool could help in determining which.
With it being both sides it might be that an X pipe was installed, removed and replaced, and the sensors or CATs were played with. If the CATs (connected to the OEM H pipe) were hanging on a fence somewhere and got water in them (Maybe from the rain) they may have gone bad together (Rusted out.). If the sensors were installed wrong, or similarly got wet, they may be rusted out or the vent holes, as explained in the web site refered to below, may be clogged. Either way they would need replaceing.
Or, if the PO took the truck swimming and it stalled in the river, got water in the exhaust pipe and CAT(s) then they may, similarly, have rusted and gone bad. Sensors, too.
You may want to clear the codes and start from scratch.
You may find this web address helpful in determining the difference between Bank 1 and Bank 2 as well as how to check the sensors w/ a scantool.....
OXYGEN SENSORS
As I understand it CATs can't be tested. Only the sensors. If the sensors are good the CAT(s) are bad. If the sensors are bad then replace the sensors and retest.
Old 04-12-2010, 09:12 AM
KhanTyranitar
This area is my expertise. The P0420 and P0430 codes are pretty conclusive that the cats are not performing like they should. Weak sensors will not trigger these codes. However, weak sensors can cause the damage to the converters that in turn results in the codes.
There is a good chance the previous owner may have tampered with the converters, maybe you should take a look and make sure they have not been eliminated.
Old 04-18-2010, 02:08 PM
prochamp's Avatar
prochamp
prochamp is offline
Well I checked the vaccum from the intake and the truck held 20psi. Had a person in the truck and had him bring the rpm up to 2500 and the vaccum dropped when we brought the rpm up but came back pretty quickly to 20 psi while holding the rpm steady at 2500. That tells me there is not a back pressure problem. The cat could be bad but they are not plugged. I decided to replace both down stream O2 sensors. Figured I would spend the extra money and get them from the dealer. I cleared the codes before I replaced them and the check engine light would come back on at 45 miles. After replacing the down stream sensors I have put about 220 miles on the truck and the light has stayed out. Hooked the scanner up and it read..( pass no codes found ) I'm hoping I got the problem solved.
Old 04-18-2010, 03:12 PM
ke6zmy's Avatar
ke6zmy
ke6zmy is offline
Congrates!!!!!!
Good feed back & info.
Thanks for the update.
advocate
1997 - 2003 F150
10-02-2023 09:32 PM
Utahdrivin
67
10-01-2023 08:46 PM
sudsmcduff
2009 - 2014 F150
07-26-2017 09:06 PM
ckellis89
2004 - 2008 F150
04-05-2016 06:16 PM
cottrellp
2004 - 2008 F150
06-13-2010 06:21 PM
Quick Reply: BOTH P0420 AND P0430 CODES
