Bad white smoke after new injectors
I recently did the diy stage 1's and man do i like the power difference they make.
After the install though I have alot of white smoke on start up definitly more than normal. I checked all the glow plugs when i had the covers off and they all checked good. I replaced all the o-rings and everthing went well. the smoke is real bad on inital start then slowly goes away but has to be driven to completly go away. I realize some smoke is normal but this is worse than normal. Its almost embarasing to start in front of my house.
I thought it may go away on its own after time but its been a couple thousand miles.
Any ideas what could be causing this ?
Where are you at with this? do you think perhaps an injector is not seated completely or an O-ring got pinched or damaged allowing oil to drip onto the cylinder while it sits? are you sure you have the copper washer between the injector tip and cylinder seat installed? does the smoke smell like raw diesel? have you taken a compression test?
salem747
07-18-2017 10:44 AM
Macmathews
03-11-2016 09:49 AM
