You know, sometimes I just have one of those days where my brain doesn't work very well. Thank you for looking, but I just found the same tag under my hood and for some reason I just didn't think to look there. I need some sleep, I did 1400 miles in 2 days and I'm wore slap out. Thanks again for looking
And you know to add refrigerant it's the larger line you want to add to, that's the suction line and if it not totally empty you wont need to add the total amount. Be sure not to get any air in the system as this will cause the discharge pressure to run higher and the system will not perform properly.
I'm probably going to take it tomorrow to Legacy Ford where my brother-in-law works and have him just do a complete check on it. All I'll get charged for is the freon.
I've done it on other vehicles, but not this new. I'm sure if I took my time I could figure it out, but I'd rather let someone else do it, so I don't waste all day trying.
