how much refrigerant
Old 04-03-2010, 04:47 PM
frankyford's Avatar
frankyford
frankyford is offline
How many pounds or cans of A/C refrigerant goes in a 2003 ford excursion with the 5.4L. Also is it pretty easy to find where to put it in. Thanks
Old 04-03-2010, 05:14 PM
cbradford's Avatar
cbradford
cbradford is offline
Do you have rear A/C?
Old 04-03-2010, 05:16 PM
frankyford's Avatar
frankyford
Yes, it's got rear A/C.
Old 04-03-2010, 05:19 PM
cbradford's Avatar
cbradford
I posted a pic of the tag awhile back, I'll see if I can find.
frankyford's Avatar
frankyford
Thank you sir
Old 04-03-2010, 05:25 PM
cbradford's Avatar
cbradford
Excursion with rear A/C= 4lb 4oz
Here you go:
Old 04-03-2010, 05:37 PM
frankyford's Avatar
frankyford
You know, sometimes I just have one of those days where my brain doesn't work very well. Thank you for looking, but I just found the same tag under my hood and for some reason I just didn't think to look there. I need some sleep, I did 1400 miles in 2 days and I'm wore slap out. Thanks again for looking
Old 04-03-2010, 05:56 PM
cbradford's Avatar
cbradford
Does your sticker indicate the same amount as mine?
Old 04-04-2010, 07:26 AM
frankyford's Avatar
frankyford
Yeah, it's the exact same one. I just didn't think to look there, I did however look in the owners manual but it wasn't in there.
Old 04-04-2010, 07:51 AM
cbradford's Avatar
cbradford
And you know to add refrigerant it's the larger line you want to add to, that's the suction line and if it not totally empty you wont need to add the total amount. Be sure not to get any air in the system as this will cause the discharge pressure to run higher and the system will not perform properly.
Old 04-04-2010, 08:05 AM
frankyford's Avatar
frankyford
I'm probably going to take it tomorrow to Legacy Ford where my brother-in-law works and have him just do a complete check on it. All I'll get charged for is the freon.
Old 04-04-2010, 08:11 AM
cbradford's Avatar
cbradford
Might be a good idea if your not sure what your doing, plus you need a manifold gauge set to properly add refrigerant.
Old 04-04-2010, 08:14 AM
frankyford's Avatar
frankyford
I've done it on other vehicles, but not this new. I'm sure if I took my time I could figure it out, but I'd rather let someone else do it, so I don't waste all day trying.
WRABER
05-01-2015 04:54 PM
holdtyte
03-23-2014 06:16 PM
pilgrimbizket
04-28-2013 02:50 PM
Talyn
08-10-2011 05:29 PM
f100guy
04-25-2007 06:07 AM
Quick Reply: how much refrigerant
