Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
93 lightning-too much compression?
Old 02-02-2003, 12:46 PM
jeff moon's Avatar
jeff moon
jeff moon is offline
I am going from 65.5 cc head chamber volume to 61cc. how much should this add to my compression ratio - I have a 351w .030 over
(93 lightning) the motor has 2000 miles on stock rebuild. It has a 6 psi ford motorsports supercharger (powerdyne) I have a new set of trick flow twisted wedge heads (61cc) that i want to installwould this increase my compression too much for the supercharger? I was told the
original gt40 heads have 65.5cc ( but i dont know for sure?) any answers or advice would be greatly appreciated Thanks jeff moon (my compression ratio right now should be around 8.8? right now)
Old 02-03-2003, 07:00 AM
DeenHylton's Avatar
DeenHylton
DeenHylton is offline
Weiands tech manual on supercharging states you need to keep your "effective" compression ratio at 12:1 or below when running pump gas (92 Octane). According to their charts 8.5:1 compression and 6 pounds boost equals 12.0 effective compression...the maximum you should be running.
Your guess-timated 9.3 compression with 6 pounds boost will equal 13:1 effective compression. I'd say you'll have to run some sort of boost retard timing control to control detonation...Deen
Rusty_S
07-22-2015 01:40 PM
bigfootsurfin
19
01-02-2015 01:48 PM
Wodahs
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-22-2014 04:05 AM
Frankinstine
20
05-30-2014 02:46 PM
WALFORD'S 56
18
11-07-2011 10:24 AM
Quick Reply: 93 lightning-too much compression?
