supercharge a 272 yblock
I have a paxton supercharger left over from my 1963 Studebaker Avanti R2. I want to install it on my 56 ford 272 and wonder if anyone out there has done this? I think my compression ratio is low enough to be ok. Let me in on any problems you may see and if the 272 performs as good as the Stude 289-it should work out good.THANKS
Before I would consider boosting a 272 Y Block, I would check all the technical info at Ford-Y-Block.com There are many pages of good info including all the work they are doing with the Y-Block. I don't think any of the 272 engines had reinforced cyl heads and many of the early attempts at boosting power resulted in broken combustion chambers. Good luck
Originally Posted by BigF350
It was a Mccullough supercharger, first fitted to Ford's as aftermarket equipment in 1950.
Came as a factory option on T-Birds in 57 I believe.
The famous F Bird..so called because engine code was an F.
There was also an E Bird...dual quads...
Both were 312's.
McCollough was bought by Paxton...Paxton blowers were installed on 1963/64 Studebaker R2 Super Larks, Super Hawks, and Avanti's.
The 289 (originally 232-1951) Studebaker engine is a direct copy of the 1949 Cadillac OHV 331ci engine, it bears no relationship to a Ford 289. The 4V intake manifold from the Cadillac is a bolt on to the Studie engine, but the Studie manifold won't fit the Cadillac. Studie V8's used solid lifters, Cads had hydraulic lifters.
And outlawed in NA$CAR in the same year... along with Fuel Injection...
The Supercharger on an Avanti R2 should be the VS57... I think (can't recall though, so check) which was designed originally for the Y-Block.
You might be able to find the mounting brackets for it on e-bay or the like.
I know a guy that has ALL the goodies to mount the blower to the Y block.
Besides Corvettes, Pontiac had FI in 1957/58.
He also bought the London Bridge and brought it to Arizona, which has nothing to do with this thread, but I thought it was interesting.
There were F code fairlanes in '57 also. Duel Quad was the E Code.
Robert P. McCulloch - Wikipedia, the free encyclopedia
Anyway, the Stude S/C should work on the 272, providing you can find all the correct mounting hardware and pulleys. Check Mummert, he has some repro S/C parts.
Looks like my biggest issue is finding a supercharger that still works.
