Coolant filter plugged after only 200 miles!
Old 03-31-2010, 03:04 PM
mufflerbearing's Avatar
mufflerbearing
mufflerbearing is offline
I flushed my cooling system and replaced the coolant with ELC 200 miles ago. While I was in there, I installed the dieselsite coolant filter. Well, the other day I when to check my coolant filter and it was ice cold after driving 20 minutes. So I stopped by napa today and picked up a new filter. When I changed it, I chopped open the old one to see what was in it. It was full of what looks like jell-o. WTF? There eas also sand in there which is to be expected but the gel stuff has me worried. It looks like (and probably is) gelled coolant. I am worried that it just filtered out the coolant part and lowered my % of coolant in the system.
Any thoughts? Coolant is Zerex heavy duty ELC coolant.
Old 03-31-2010, 03:12 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Jell-O? Did you do a good enough flush before you put the ELC in? What year is your truck, and did you have green in it before?
Old 03-31-2010, 04:05 PM
mufflerbearing
I flushed through a LOT of water, so I doubt that is the problem. Took the thermostat out and everything.
It's a 2000 7.3 that came from the factory with green coolant.
Old 03-31-2010, 04:15 PM
CPUNeck's Avatar
CPUNeck
CPUNeck is offline
That would be fall out. Same thing happened to me. Second filter, no problems.
Old 03-31-2010, 04:16 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Did you use distilled water to flush the system? Did you do a complete flush as in remove the block drain plugs?
When you mix OAT (green) and ELC the reaction between the two is Jello. This is not good. Usually you have a lot of sand in the filter not jello.
Old 03-31-2010, 04:17 PM
patrickke's Avatar
patrickke
patrickke is offline
hmmm... it seems like it could have been the filter itself, it could have had some kind of chemical in it
Old 03-31-2010, 04:22 PM
spdmpo's Avatar
spdmpo
spdmpo is offline
Or he didn't get all of the green out.
Old 03-31-2010, 04:32 PM
patrickke's Avatar
patrickke
this is true
Old 03-31-2010, 04:43 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Hope you're not using filters charged with SCAs!! That would do it too. AND you need to flush the system again.........
Old 03-31-2010, 05:05 PM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
Do the Baldwin Filters from Dieselsite have SCAs in them?
Old 03-31-2010, 05:48 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I have no idea, but I would guess Bob sells both. Look up the part number of the one you have and see what it says. Or call Bob. LOL
Old 03-31-2010, 06:52 PM
mufflerbearing
It is supposed not to have any SCA's in the baldwin filter. I know the napa gold filter I just picked up doesn't have any.
here's pics:
Old 03-31-2010, 07:10 PM
big poppa's Avatar
big poppa
big poppa is offline
Bob sells the NO precharged Baldwin filters, he doesn't like them and for obvious reasons. B-5134 filters for our applications. Also, at 10.50 a filter, they are rather inexspensive IMO opposed to other places.
Old 04-22-2010, 06:56 PM
mufflerbearing
Just want to let you guys know that I put a good 500+ miles on the napa filter and it is still flowing like new. I duno why that first filter plugged up with gel. All seems to be good now.
Old 04-22-2010, 07:19 PM
big poppa's Avatar
big poppa
Very good to know, appreciate the update, and glad things are back to normal..
Quick Reply: Coolant filter plugged after only 200 miles!
