Remanufactured ammo
Remanufactured ammo
Anyone have any opinions on the use of remanufactured ammunition? Typically, they're bulk reloaded using once-shot brass that's not deformed.
Cabela's and a bunch of internet speciality stores offer bulk packages of reman ammo in lots of 100 to 500 rounds for almost all calibers.
I can get 100 round boxes of 45ACP for around 35 bucks, plus shipping (shipping to Illinois is another story) but here in Cook County, I'll spend 30 bucks or more just for one box of factory rounds.
I don't get to shoot a lot, but I like to hit the range when I have a few extra bucks. I don't really have the space to do my own reloading, although I've never reloaded anything beyond shotshells.
Just wondering if anyone has any experience with ammo like this? Any feeding issues or the like.
Can`t see that it would be any different from home loaded once fired cases.
As for space required I used to reload .45ACP using a tong tool. Only needed the kitchen table for a couple of hours and then everyting packed away in the box again. Very time consuming though.
Ammo became cheap and I stopped reloading but the way prices are going now I may give it a go again.
Used to cast the bullets but that was a PITA.
Reloads from a reputable dealer can be very good. Reloads from ranges and such are all over the quality spectrum. All depends on who did the work and their equipment and components. I would not worry about a Cabelas reload, probably good as new and backed by their reputation.
If shopping around... Take a good look at the reloads. Any physical damage such as dents dirt, cracks, shaved metal curliques, not seated primers etc would be the first level of inspection. If you see any of these problems I would probably not buy. Next, if you do buy, try some out at the range. Check for sure fire, accuracy, reliability in the gun, any funny or off sounds while firing. IF all things look good, I would probably use that supplier again.
Reloading at home can be done fairly easily. When I was single, I used to use a small Lee Turret press mounted on a 2x8 board slid between the cracks of two kitchen chairs back to back. It worked. I loaded thousands of rounds that way in my living room. I had to stop after I got married and a few stray live primers exploded inside the vacuum cleaner when my wife vacuumed the **** carpet. It was fun while it lasted. Now I load at a bench in the garage.
45 rounds are some of the easiest to reload since they are straight walled and fairly low pressure. A little pistol powder goes a long way. Hard lead bullets and copper jackets work well. Round nose is most reliable and truncated cones are OK in better guns. With a turret press I can easily load 100+ rounds an hour using it like a single stage press, ie deprime resize all, then hand prime all, then hand fill powder, then seat bullets. The more automatic presses can do hundreds per hour easily.
Right now even components are expensive and sometimes hard to obtain. But lots cheaper than factory ammo.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
There's not much left to add to Jim's post.
I'm not a fan of soft/swaged bullets, so, I'd ask them if these are 'hardcast' or 'swaged'.
The swaged bullets are softer, and will cause 'leading' a lot faster than hardcast.
$35.00 per shipping is a little high, especially when you add shipping charges. However, IF they have it in stock. . .
So many places don't have ammo right now.
Make sure it's full length resized, the only time you should expect neck resized to function reliably is when it came from your gun the first time around. Otherwise, nothing wrong with reloads.
Reloading yourself has some huge advantages too, since you can play around with different powders, different bullet shapes, and in general come up with a shell tuned to your shooting style and gun.
What are you buying? For me reman ammo has always been a luck of the draw. I've had the best luck with the ultramax in 223 and 38 special. I'd also use the 45 or 9mm. I would never shoot a 40 reload. Another good one is Georgia Arms. But I'd stick with a large known company. Anything that comes in a clear plastic bag seems to be a guy in his basement cranking stuff out. If you can can try reloading yourself. Its not hard (unless you start your own recipes) and you never run out of ammo. Be advised you wont save any money reloading vs. buying cause you end up shooting twice as much!
The only reason I haven't really considered reloading myself is because I don't have the chance to shoot often, and it's easier to hide a case of ammo from the wife than all the kit to make my own.
I'll keep doing my research, and I won't jump into anything just yet. I'll probably stick with a bigger name company or distributor like Cabela's, but we'll see what I find out.
Thanks a ton guys, the help is appreiciated.
FordTruckGuySTX
19
10-10-2005 07:02 AM
Momudder720
13
04-08-2004 10:18 AM
