351m cam bearing guestion.
Old 03-30-2010, 09:52 AM
triplecreek's Avatar
triplecreek
triplecreek is offline
Droped my oil pan to to instal a new oilpump had pices of cam bearing in the pan. If I spun a cam bearing is my motor scrap now?
What other motors will bolt up to my C6 tranny?
Old 03-30-2010, 10:04 AM
mustang81's Avatar
mustang81
mustang81 is offline
Are you sure is the cam bearing ? I would say connecting rod bearing. Cam bearing don't wear as fast because the cam turn 2 time slower than the crank. If you don't have knocking problem before, i would check crank mesurement and if good i would put new connecting rod bearing. What is the milage on that motor ?
400,429 and the 460 share the same bellhousing pattern than the 351m.
Old 03-30-2010, 10:07 AM
mark a.'s Avatar
mark a.
mark a. is online now
The block would probably be junk if that happened. What makes you think that ? A 400 is a direct replacement. A 429-460 will bolt to your c6 but there will be things to deal with. Motor mounts, exhaust, radiator, power steering & alt brackets, etc.
Old 03-30-2010, 11:01 AM
triplecreek
Here is what was in the pan. It is really soft and can be pullen apart with my hands.
Here is the cam with a pice sticking out .
Old 03-30-2010, 11:05 AM
triplecreek
I done a cost on a rebuilt about 900.00 I can buy a new reman for 1200.00 with a 3 year warrentie. the motor and tranny will be the only part of my truck that I will not have worked on my self. I have never rebuilt a motor, I belive I could do it but hate to spend the money only to have it not run right.
Old 03-30-2010, 02:57 PM
mark a.'s Avatar
mark a.
I guess all you can do now is tear it down and see how bad it is.
Old 03-31-2010, 12:13 PM
mustang81's Avatar
mustang81
cam bearing can be change with a special tool but the motor have to be remove. probably need a complete rebuild. Good time to raise the compression and install a bigger cam to make the real horspower and torque the 400 is capable. Look for a 400 crank, pistons have to be change anyway and the connecting are the same. so give a call or go to www.Tmeyerinc. He have anything you'll need.
twigs
13
02-11-2016 08:00 AM
Jxltrucking
08-23-2015 03:55 AM
IntheTrees
08-04-2009 07:19 AM
JCoggin
11-14-2007 11:16 AM
mcne
32
12-09-2005 07:31 PM
Quick Reply: 351m cam bearing guestion.
